Fix GPencil selection workaround used for T62101
Closed, ResolvedPublicTO DO
After the release of 2.80, fix this asap. The workaround used for T62101 must be removed.
Assigned initially to @Clément Foucault (fclem) because he will coordinate the change.
See D5193 for more details
Antonio Vazquez (antoniov) lowered the priority of this task from 90 to High.Jul 5 2019, 11:51 PM
Antonio Vazquez (antoniov) created this task.
Clément Foucault (fclem) lowered the priority of this task from High to Normal.Jul 7 2019, 2:52 PM
Antonio Vazquez (antoniov) renamed this task from Fix GPencil selection workaround used for T62101 (after 2.80 release) to Fix GPencil selection workaround used for T62101.Jul 24 2019, 3:15 PM
Changing After Release to 2.81, since we are now using milestones instead.
I don't know if this is one is actually planned for 2.81, feel free to adjust tags as needed.
@Antonio Vazquez (antoniov), is this still planned for 2.81? If not the tag can be changed from 2.81 to 2.82.
Doesn't look like a 2.81 target then.
Clément Foucault (fclem) closed this task as Resolved.Jan 13 2020, 4:43 PM
Fixed in gpencil-refactor branch.
