Crease Function in Multires modifier
Closed, DuplicatePublic
Operating system: MacOS (current Mojave 10.14.5)
Graphics card: Radeon Pro 570 4GB
Broken: 2.80 Beta
Multires Modifier shows strange functionality with creases. It seems to invert the crease profile.
Sudivision Surface Creases are excellent.
-Default cube, in edit mode crease edges to 0.50.
-Object mode add Multires modifier.
-Subdivide a few times inside the modifier.
Thank You,
James
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jul 10 2019, 10:41 AM
I can not reproduce this, using a cube with a subdiv modifier gives the same result.
Does this still happen with the latest blender beta?
Hello Sebastian,
Thanks for getting back to me on this. I've reproduced the error on a Windows machine and attached the file.
*if the Mean Crease is set to 1.00, everything functions as normal. If it is set to anything below (0.3, 0.5, etc.) the error occurs.
Once again if you use a Subdivision Surface modifier everything is perfect. However, if you use Multiresolution modifier instead, the creased edges produce a strange error.
Thanks Again,
James Light
Sebastian Parborg (zeddb) raised the priority of this task from 30 to 50.
This is caused by a transitional state of code, where Subdivide uses old subdivision algorithm, but sculpting and drawing are using new one: causes mismatch how displacement is being updated and propagated.
