bpy.ops.transform.rotate works incorrect if not set "orient_matrix" value #66527
Closed
opened 2019-07-07 14:31:46 +02:00 by Ivan Vostrikov · 13 comments
Graphics card: GeForce 920M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.81
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-05 16:36, hash: 699193713f
Worked: 2.79b
If not set "orient_matrix" value in operator bpy.ops.transform.rotate, object will be rotate in anoter side. This works for GLOBAL and LOCAL orientations.
For Example:
bpy.ops.transform.rotate(value=0.349066, orient_axis='Y', orient_type='GLOBAL', orient_matrix_type='GLOBAL', constraint_axis=(False, True, False)) must rotate global Y axis 20 degrees.
In fact: Rotate global Y axis -20 degrees.
or
bpy.ops.transform.rotate(value=0.349066, orient_axis='X', orient_type='LOCAL', orient_matrix_type='LOCAL', constraint_axis=(True, False, False)) must rotate local X axis 20 degrees.
In fact: Rotate local X axis -20 degrees.
  • Create New File and select Default Cube
  • Open Python Console
  • Run: bpy.ops.transform.rotate(value=0.349066, orient_axis='Y', orient_type='GLOBAL', orient_matrix_type='GLOBAL', constraint_axis=(False, True, False)) or bpy.ops.transform.rotate(value=0.349066, orient_axis='X', orient_type='LOCAL', orient_matrix_type='LOCAL', constraint_axis=(True, False, False))
  • Check result cube's rotation
**System Information** Operating system: Windows-10-10.0.17134 64 Bits Graphics card: GeForce 920M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.81 **Blender Version** Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-05 16:36, hash: `699193713f` Worked: 2.79b **Short description of error** If not set "orient_matrix" value in operator bpy.ops.transform.rotate, object will be rotate in anoter side. This works for GLOBAL and LOCAL orientations. For Example: bpy.ops.transform.rotate(value=0.349066, orient_axis='Y', orient_type='GLOBAL', orient_matrix_type='GLOBAL', constraint_axis=(False, True, False)) **must rotate global Y axis 20 degrees.** **In fact: Rotate global Y axis -20 degrees.** **or** bpy.ops.transform.rotate(value=0.349066, orient_axis='X', orient_type='LOCAL', orient_matrix_type='LOCAL', constraint_axis=(True, False, False)) **must rotate local X axis 20 degrees.** **In fact: Rotate local X axis -20 degrees.** **Exact steps for others to reproduce the error** - Create New File and select Default Cube - Open Python Console - Run: bpy.ops.transform.rotate(value=0.349066, orient_axis='Y', orient_type='GLOBAL', orient_matrix_type='GLOBAL', constraint_axis=(False, True, False)) **or** bpy.ops.transform.rotate(value=0.349066, orient_axis='X', orient_type='LOCAL', orient_matrix_type='LOCAL', constraint_axis=(True, False, False)) - Check result cube's rotation
Author
Added subscriber: @IvanVostrikov
Member
Added subscribers: @ideasman42, @lichtwerk
Campbell Barton was assigned by Philipp Oeser 2019-07-08 13:43:38 +02:00
Member
Confirmed.
@ideasman42 : just guessing: not sure why we are inverting spacemtx in initTransformOrientation here (if skipped for for the non-modal case, issue seems to be gone...)?
Confirmed. @ideasman42 : just guessing: not sure why we are inverting `spacemtx` in `initTransformOrientation` [here ](https://developer.blender.org/diffusion/B/browse/master/source/blender/editors/transform/transform_orientations.c$518) (if skipped for for the non-modal case, issue seems to be gone...)?
Added subscriber: @LajosMagvasi
Also If you set the orientation type to VIEW and dont set the orient_matrix, it will use the global orientation.
Campbell Barton was unassigned by Dalai Felinto 2019-12-23 16:33:54 +01:00
Added subscriber: @richeyrose
This bug was gone in 2.90.1 but has now reappeared in 2.91 and is even worse as setting orient_matrix no longer prevents the bug. As far as I can tell there is now no way to get transform.rotate to output a none reversed rotation without inverting a value.
Member
Since this is a bit of a new situation in 2.91, could you make a new report for this?
(you can also reference this report in the new one, but overall, this will make it easier to track progress, thx)
> In #66527#1061767, @richeyrose wrote: > This bug was gone in 2.90.1 but has now reappeared in 2.91 and is even worse as setting orient_matrix no longer prevents the bug. As far as I can tell there is now no way to get transform.rotate to output a none reversed rotation without inverting a value. Since this is a bit of a new situation in 2.91, could you make a new report for this? (you can also reference this report in the new one, but overall, this will make it easier to track progress, thx)
Done https://developer.blender.org/T83092
Now effects Mesh edit and pose mode as well. Ouch
Done https://developer.blender.org/T83092 Now effects Mesh edit and pose mode as well. Ouch
Member
Member
Can not replicate the issue. Checked with 2.93 LTS and 3.0.0 (d1e1d6c491). Issue was there in 2.92 release.
Hi @lichtwerk , are you able to reproduce the problem with 2.93LTS?
Output:
2.92 2.93LTS
Can not replicate the issue. Checked with 2.93 LTS and 3.0.0 (`d1e1d6c491`). Issue was there in 2.92 release. Hi @lichtwerk , are you able to reproduce the problem with 2.93LTS? Output: |2.92|2.93LTS| | -- | -- | |![prog.PNG](https://archive.blender.org/developer/F10233658/prog.PNG)|![prog.PNG](https://archive.blender.org/developer/F10233663/prog.PNG)|
Member
Philipp Oeser self-assigned this 2021-07-23 13:12:56 +02:00
Member
This was fixed by 92743cc895, so bug is not in 2.93 nor 3.0.
Will close as resolved (but of course feel free to comment again if issues persist)
This was fixed by 92743cc895, so bug is not in 2.93 nor 3.0. Will close as resolved (but of course feel free to comment again if issues persist)
5 Participants
Reference: blender/blender#66527
