Boolean Modifier gives unpredictable results when executed in a loop via Python API #66593
Reference: blender/blender#66593
Graphics card: Intel(R) HD Graphics 530 Intel 4.5.0 - Build 25.20.100.6373
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-08 23:33, hash:
ac8c795429
When I try to use Boolean Modifier for a set of meshes in a loop via Python API I get some weird results. For instance, some meshes get joined with target object.
Code to execute:
Blend file:
Boolean_Bug.blend
Video of the problem:
Boolean_video.mp4
Added subscriber: @WannaBe
Added subscriber: @dr.sybren
I can't reproduce this (Blender
516afd0162
), for me the script doesn't do anything. Looking at the code, the 'wall slicer' doesn't intersect with any walls (I put abreak
in the code to stop it after the wall slicer was created):So for me the script works as expected, I guess.
Added subscriber: @ZedDB
Exactly what do you expect the code to do? The walls are have zero width so they will probably now work nicely with any boolean operation.
I've attached the video that shows the problem. Two planes were cut as expected, whereas other two merged with their target object (wall_slicer).
Added subscriber: @capnm
It has nothing to do with the Python API. You get the same bad results when you try it in the UI.
AFAICT the solver in blender8 only gives much worse results here than in blender7:
My bad... I thought that the problem was caused by looping. It seems that orientation in space matters for Boolean Modifier.
Ah right, I'll take this back, I accidentally rotated the view in Blender 2.7x, the results of the boolean-op are the same ...
Right, this is not a bug but a limitation of the boolean modifier. There are plans to make it better in the future, and we already have tasks for that. So I'll close this.
https://developer.blender.org/T47030 ;-)
To make the current boolean operator work in a script or addon, you have to randomize/tweak the size or rotation of the 'cutter' mesh.
Thanks for your hint!
