Inconsistent data-block pin behavior
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.64
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-01 15:48, hash: rBdcf520cdad79
Current opened tab determines availability of mesh data of pinned object
  1. Select default cube
  2. Go to mesh tab
  3. Pin cube (shape keys and vertex groups are not there)
  4. Unpin cube
  5. Go to Modifiers tab
  6. Pin again
  7. Now in mesh tab you can see shape keys and other stuff
Sybren A. Stüvel (sybren) triaged this task as Needs Information from User priority.
Your Blender is more than a week old, and a lot of development happened since then. Please test with the latest daily build from https://builder.blender.org/download/
build 2019-07-10 10:32, hash: rB12ceea04344a
same issue
Sybren A. Stüvel (sybren) claimed this task.
I checked with the UI team, and this is working as designed. When you pin in the mesh panel, you pin the mesh itself. The vertex groups and shape keys are defined on the object, so they disappear. When you pin from the modifiers tab, you pin the object, so you still have access to its mesh. The same is true for lamps, cameras, materials, etc.
