Object not in View Layer error when trying to select a new object in a new scene from a panel.
Closed, InvalidPublic
Operating system: Windows 8.1
Broken: 2.80, 2019-07-10
In a python script, calling object.select_set(True) on a just-created object in a just-created scene can cause the error: "RuntimeError: Error: Object 'Test' not in View Layer 'View Layer'!".
Strangely, this error only happens when the operator performing these functions is called from a panel.
It does not happen when the operator is called directly from the F3 search menu.
Put the following code in a text area and run the script:
import bpy
class SimplePanel(bpy.types.Panel):
    bl_label = "Simple Panel"
    bl_space_type = 'PROPERTIES'
    bl_region_type = 'WINDOW'
    bl_context = "scene"
    def draw(self, context):
        layout = self.layout
        layout.operator("object.simple_operator")
class SimpleOperator(bpy.types.Operator):
    bl_idname = "object.simple_operator"
    bl_label = "Simple Object Operator"
    def execute(self, context):
        scene = bpy.data.scenes.new('Test')
        bpy.context.window.scene = scene
        testob = bpy.data.objects.new(name='Test', object_data=None)
        scene.collection.objects.link(testob)
        testob.select_set(True)
        return{'FINISHED'}
def register():
    bpy.utils.register_class(SimpleOperator)
    bpy.utils.register_class(SimplePanel)
if __name__ == "__main__":
    register()
Click the "Simple Object Operator" button in the new "Simple Panel".
Note: ive tried a wide variety of update functions thrown in various places, including view_layer.update(), view_layer.objects.update() both on scene, and context.scene, and context.evaluated_depsgraph_get().update(), nothing seems to help.
Sebastian Parborg (zeddb) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
Thanks for the report, but you are creating a new scene in your script, you need to pass the new view_layer to the select_set function:
testob.select_set(True, view_layer=scene.view_layers[0])
