Grease Pencil Build and Simplify Modifier Order Ignored #66744
6 Participants
Reference: blender/blender#66744
Operating system: Windows 10 64 bit
Graphics card: Nvidia GTX 750 Ti
Broken: blender-2.80.0-git.d663048696b2-windows64
If a Grease Pencil Object has both a Simplify and Build Modifier, it doesn't matter which order they come in.
It always behaves as if the Simplify Modifier came after the Build Modifier.
I'd expect Simplify before Build to behave as if the Simplify Modifier was applied first.
GreaseBuild.blend
From left to right:
As you can see, 1 and 2 behave the same (when you play the animation).
However, I'd expect 1 to behave the same as 3.
Added subscriber: @Foaly
IIRC this is how is designed because there are several types (internally) of modifiers... modifiers that change geometry, modifiers that generate geometry and modifiers that use time.
I will review, but I think this is a problem of communicate this and explain how and why the modifiers are evaluated in that way.
Added subscriber: @ZedDB
@ZedDB I have been looking at the code, and the build modifier must be evaluated before the others modifiers due this modifier needs to read all frames to decide what to do, but the other modifiers only read the current frame and strokes.
Run Build before is done for data access and also for performance, so all geometry modifiers (Build, Mirror and Array) run first, and then all modify modifiers. Time modifier plays totatlly different.
I don't think we can change this or consider as a bug, but a limitation of what you can do with modifiers... maybe we could add some type of warning on modifier panel to inform about this.
Note: For 2.81 I'm going to replace where the modifiers are evaluated (see #66294). I have the change done in greasepencil branch, but we decided not to move to 2.80 and wait for 2.81.
@antoniov How about we make it so that the build modifier adds a warning to its UI if it is not first in the stack?
Yes, this is the idea... I have seen this before in the code for some modifiers, but don't remember where
Added subscriber: @antoniov
Added subscriber: @mont29
That is a fairly sever usability issue, order in the stack should always be actual order of evaluation. If some modifiers need to run first, then they should be forcefully put in first positions of the stack.
We have that with regular Object modifier e.g., Multires cannot be moved or added after a modifier like Build, because the latter breaks access to mesh orig data needed by multiress…
It is most likely too late to address that in 2.82, but would consider it a show-stopper for 2.83 then. You cannot expect users to guess the actual order of evaluation, they have to get what they see here. ;)
@mont29 Are there any tag to force a modifier to be first in stack?
@antoniov For 'regular' data check
eModifierTypeFlag_RequiresOriginalData
flag inBKE_modifier.h
. However if you have three different 'stages' you'll probably need another extra tag for the second stage?I'm going to refactor the modifier loop to use the order on the stack. All the changes will be done in greasepencil-refactor branch, because we have changed all modifiers evaluation for the new drawing engine.
I don't think we must consider as high priority, just a Know Limitation that will be fixed in 2.83 with the new engine and evaluation logic.
This is fixed in the branch in commit: d0b8b49b447b
We keep this as Know Issue in this version because it will be fixed when the refactor branch will be merged in master branch.
Added subscriber: @brecht
Is this fixed now?
Yes, fixed in 2.83
