macOS missing shortcuts and menu entries with 2.80 RC1
Operating system: OSX 10.14.5
Graphics card: radeon Pro Vega 64 16Gb
Broken: RC1 - July12
Installed RC1 on my Mac - config/prefs not recognized. Splash screen not showing proper and hot keys not working(i.e. t or n keys)
Launched RC1 and does not recognize startup/config file/locations. removed those and then tried startup again. same problem,
There are a very large number of changes, so older changes are hidden. Show Older Changes
work fine on 2.8 beta 7ad21c3876c2
Hey just wanted to confirm. Same problem here.
  • No tools menu.
  • Splash screen is broken. No recent files etc. Just the image.
  • Keymap page is not showing up
  • Addon page is not shwing up
  • Some dropdown are broken. ( Help dropdown, blender logo dropdown,
  • Getting error while deleting objects in 3d view.
Tested on MacBook Pro (15-inch, 2016) Mac Os Mojave 10.14.5 (18F132)
I have the same issue - and also if I try to export the default cube scene - FBX, Collada, Wavefront(OBJ), X3D all crash.
Blender 2.80 (sub 74), Commit date: 2019-07-11 13:50, Hash 06312c6d2db8
File "/Applications/Blender.app/Contents/Resources/2.80/scripts/startup/bl_ui/space_toolsystem_common.py", line 611, in draw
  self.draw_cls(self.layout, context)
File "/Applications/Blender.app/Contents/Resources/2.80/scripts/startup/bl_ui/space_toolsystem_common.py", line 599, in draw_cls
  ).name = item.idname
AttributeError: 'NoneType' object has no attribute 'name'
  1. Error
backtrace
0 Blender 0x000000010acef937 BLI_system_backtrace + 55
1 Blender 0x000000010aa1dfda sig_handle_crash + 362
2 libsystem_platform.dylib 0x00007fff5c2e2b5d _sigtramp + 29
3 ??? 0x0000000000000000 0x0 + 0
4 Blender 0x000000010ec42528 uiTemplateOperatorPropertyButs + 280
5 Blender 0x00000001102e0404 file_panel_operator + 212
6 Blender 0x000000010ee78672 ed_panel_draw + 674
7 Blender 0x000000010ee781e9 ED_region_panels_layout_ex + 921
8 Blender 0x000000010ee78a1a ED_region_panels + 58
9 Blender 0x000000010ee74891 ED_region_do_draw + 353
10 Blender 0x000000010af148c6 wm_draw_update + 1878
11 Blender 0x000000010af12520 WM_main + 48
12 Blender 0x000000010aa1a7ef main + 927
13 libdyld.dylib 0x00007fff5c0f73d5 start + 1
Same problem here. No splash screen, no toolbar.
Having the same issues as OP.
macOS Mojave, 10.14.5
iMac (27-inch, late 2013)
Processor 3.5 Ghz Intel Core i&
Memory: 32 GB 1600 Mhz DDR3
Graphics: NVIDA GeForceGTX 780M 4GB
Attached is the txt file made with the output from the terminal after the command
/Applications/Blender.app/Contents/MacOS/Blender
was ran.
Like with the most other posters 2.80 beta from last night, blender-2.80-7ad21c3876c2-OSX-10.9-x86_64.zip, operates well with none of the issues of the RC1.
Thanks all for the reports. We've uploaded a new build here that should work:
https://download.blender.org/release/Blender2.80/blender-2.80rc1-macOS.dmg
The download on blender.org will have the fix as well, but it might take a bit for all download mirrors to be updated.
Build you just linked to fixes the issues I was seeing!!!
The problems seem to be fixed in the new download link.
Hi @Brecht Van Lommel (brecht) ,
I'm still unable to select the DOF using "DOF Distance (Pick)" on the right click menu, even with the new download link you provided.
Best,
The import/export problems persist.
This build fixed the missing Toolbar for me, thanks!
Fixed issue for me also. Thanks!
I can also confirm it fixed my issue as well.
ken wong (ken) added a comment.EditedJul 13 2019, 2:09 PM
mac osx mojave
new blender 2.8 blender-2.80rc1-macOS fixed the missing Toolbar And cycle.
but some addon like machin3tool / fluid / etc. addon , got issue when active in preference.
delete >>> application support /blender/ blender 2.80 folder
re download the 2.8 RC1 again ,
preference active got issue
@ken wong (ken) addons with issue are officially distribuited with Blender or they are 3th part addons?
message from machintool : It’s clear the RC on MacOS seems to have numpy issues. This is not related to MACHIN3tools, other than MACHIn3tools using numpy, which is a module, Blender’s python supplies by default.
Please try entering import numpy into the python console. And see what happens.
Also try on the latest experimental build, released AFTER the RC.
This worked for me also
IMHO if Cycles works , python-mumpy work. if i am not in wrong
as declarated from Blender developers; macOS python issue had been corrected yesterday 12 jul at 18pm UTC time
if you have issue with python-numpy this is wrong bug report (macOS missing shortcuts and menu entries with 2.80 RC1)
you must open new bug report or search if anyone has already open it
Addons import/export OK after "Load Factory Settings" which is like a reset system!!!
Best,
The latest beta build appears to have fixed the problem.
Thank you
mac osx mojave
I am also getting this issue when attempting to use any addon that requires ctypes. I am getting a MemoryError see this thread on devtalk for more info. Also I confirm that build 06312c6d2db8 (downloaded on the 13th of July) has this problem.
For the ctypes issues I've created T66986: macOS code signed release errors with Python ctypes.
The original bug here is solved.
