Audio SDL: Video editor Sound muted without muting it
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: rB06312c6d2db8
Worked: 2.79b
Audio playback not making any sound
add a image strip and then a mp4 video file or only the mp4 file, it just doesn't sound at all by any means
With the sound output through HDMI the file worked without problems.
But then I decided to try with a headset and the sound continued to come from the screen through the HDMI (while in other programs the sound came out through the headset).
So I went into Preferences->System->Audio Device and even choosing the same Device something updates and the sound goes out through the headset normally.
The problem must be related, but (I don't understand anything about this area).
@Joerg Mueller (nexyon), @Sergey Sharybin (sergey) any idea?
@AnityEx (AnityEx) which audio device/backend (OpenAL or SDL) are you using and does it work if you switch it under Preferences->System->Audio Device?
@Germano Cavalcante (mano-wii) this sounds like a different bug, but same question for you. Switch the device/backend in the preferences and then try to switch between headset and screen to check if it has the same problem.
The sound plays back on both macOS and Linux for me (both default OpenAL). So doesn't seem this is anything to do with the dependency graph integration or the RC build itself.
@Joerg Mueller (nexyon) SDL Does not work at all, but OpenAl and openAl-soft do work
The same situation is seen with OpenAL and OpenAL-Soft.
If I load Blender with the headset already plugged in. The sound comes from the headset.
SDL is mute both on the headset and on the screen.
Okay, from what I gather from both of you now is that OpenAL works, but SDL does not on Windows. @Ray molenkamp (LazyDodo) can you check if SDL works on windows or if it's not? Maybe we need a library update on windows?
As for the plugging in headsets @Germano Cavalcante (mano-wii), there's nothing we can do. The only thing you could try to do is to open an issue for OpenAL soft, there is already a similar one as far as I checked: https://github.com/kcat/openal-soft/issues/291
I just tested on windows. By default, openAL is selected on my computer and the sound plays normally. If I select SDL, the sound is not played whereas the sound is played both with openAL and SDL in 2.79b. When I replace 2.8 SDL2.dll with 2.79b SDL2.dll, the sound works correctly both with openAL and SDL in 2.8. Then it seems to come from SDL2 lib update in 2.8 I think
Philipp Oeser (lichtwerk) renamed this task from Video editor Sound muted without muting it to Audio SDL: Video editor Sound muted without muting it.Sep 3 2019, 2:21 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 80.
Richard Antalik (ISS) changed the task status from Needs Developer to Reproduce to Confirmed.Jan 3 2020, 1:24 AM
I should have clarified, thatI tested this on windows
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Bug".Jan 20 2020, 11:43 AM
Audaspace request AUDIO_S16SYS , SDL goes best I can do is AUDIO_F32LSB and audaspace goes , *FINE* no audio.
the SDL documentation says
If obtained is NULL, the audio data passed to the callback function will be guaranteed to be in the requested format, and will be automatically converted to the actual hardware audio format if necessary. If obtained is NULL, desired will have fields modified.
Did a quick test, and it indeed restored audio with SDL, but most of the SDLDevice ctor code can/should be removed so i'll leave it to @Joerg Mueller (nexyon) to do a proper cleanup there.
Ah, we're on SDL 2 now, and SDL 2 has new audio sample formats. Originally, the SDL backend was implemented for SDL 1.2 which had only 8 and 16 bit sample formats. If we're using SDL 2 now, it makes sense to update.
@Ray molenkamp (LazyDodo) can you please elaborate why and which code of the ctor should be removed? I think it should rather be extended to support the new sample formats... So, please try if this patch works for you:
Cheers
Given SDL is guaranteed to give us the format we want as long as we don't give it an opportunity to tell us otherwise, i was planning to go with
diff --git a/extern/audaspace/plugins/sdl/SDLDevice.cpp b/extern/audaspace/plugins/sdl/SDLDevice.cpp
index 603e16001b8..fe6deb54b24 100644
--- a/extern/audaspace/plugins/sdl/SDLDevice.cpp
+++ b/extern/audaspace/plugins/sdl/SDLDevice.cpp
@@ -58,7 +58,7 @@ SDLDevice::SDLDevice(DeviceSpecs specs, int buffersize) :
 	m_specs = specs;
-	SDL_AudioSpec format, obtained;
+	SDL_AudioSpec format;
 	format.freq = m_specs.rate;
 	if(m_specs.format == FORMAT_U8)
@@ -70,21 +70,9 @@ SDLDevice::SDLDevice(DeviceSpecs specs, int buffersize) :
 	format.callback = SDLDevice::SDL_mix;
 	format.userdata = this;
-	if(SDL_OpenAudio(&format, &obtained) != 0)
+	if(SDL_OpenAudio(&format, NULL) != 0)
 		AUD_THROW(DeviceException, "The audio device couldn't be opened with SDL.");
-	m_specs.rate = (SampleRate)obtained.freq;
-	m_specs.channels = (Channels)obtained.channels;
-	if(obtained.format == AUDIO_U8)
-		m_specs.format = FORMAT_U8;
-	else if(obtained.format == AUDIO_S16LSB || obtained.format == AUDIO_S16MSB)
-		m_specs.format = FORMAT_S16;
-	else
-		SDL_CloseAudio();
-		AUD_THROW(DeviceException, "The sample format obtained from SDL is not supported.");
 	create();
This changes behavior... So far we had it take the closest possible configuration, in the hope we can support it. That's the more user friendly solution, especially when people don't want to bother with the details of these settings.
Also your patch won't solve the issue, SDL still wouldn't work with this, since apparently the audio device in question only supports the float sample format, which is not implemented in this patch.
Did you try my patch? If not please do!
We don't need to, SDL does the conversion for us
Not yet, I'll try to do so tonight
You're right, it could do the conversion. It may also change the number of channels and resample to a different sampling rate though. All of this can possibly deteriorate the quality. For example, we want to render 3D audio to the correct speaker setup that SDL outputs with and not to a wrong one and then SDL somehow changes the channel configuration resulting in a suboptimal listening experience. That's why we would rather do these things ourselves rather than having SDL do it.
Sorry took a few days, can confirm your patch works !
