particles keep emitting from first frame location of emitter and also the first few particles appear to freeze in mid air.blend
Closed, DuplicatePublic
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: rB06312c6d2db8
particle emitting from first frame location of emitter and also the first few particles appear to freeze in mid air.blend, baking the simulation to keyframes returns the same result, so not related to:
https://developer.blender.org/T58044
add a particle system (emitter) to a moving object and press play. Happens on both rigid body dynamic driven objects and also after baking the simulation to keyframes.
See file, the particles initially emitted float in mid air completely frozen, whilst more particles continue to emit from that same location. Particles also continue emitting from the moving emitter.
It is related as the evaluation of rigidbodies are still evaluated the same way regardless of if you are baking or not.
Actually, the issue here seem that you also have a very bad dependency cycle in the example file. So that is an additional reason why it is not working.
