Alembic cache induces flickering and change of position on hair driven by that surfaces connected to it. #67038
Closed
opened 2019-07-16 06:39:14 +02:00 by carlos puebla · 5 comments
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: 06312c6d2d
Hair changes every frame when is driven by a surface using an alembic cache (cache sequencer ). The position of every strand is lost, not a big changes but subtle .When i change to an mdd cache all works as expected .constant position in hairs, no flicker .
Open scene with an object with hair, create a Mesh Sequence Cache modifier on it to drive it , connect it to the proper abc file , and the right object path .Render a few frames.Result flicker
the same procedure changing to a Mesh Cache( with .mdd ) modifier render a few frames , works fine.
In viewport al works fine in both ways .The hairs doesn't varies his position.
note.The zip file contains also cache files in relative path way
alembic flicker hair.zip
**System Information** Operating system: Windows-7-6.1.7601-SP1 64 Bits Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86 **Blender Version** Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: `06312c6d2d` Worked: (optional) **Short description of error** Hair changes every frame when is driven by a surface using an alembic cache (cache sequencer ). The position of every strand is lost, not a big changes but subtle .When i change to an mdd cache all works as expected .constant position in hairs, no flicker . **Exact steps for others to reproduce the error** Open scene with an object with hair, create a Mesh Sequence Cache modifier on it to drive it , connect it to the proper abc file , and the right object path .Render a few frames.Result flicker the same procedure changing to a Mesh Cache( with .mdd ) modifier render a few frames , works fine. In viewport al works fine in both ways .The hairs doesn't varies his position. note.The zip file contains also cache files in relative path way [Based on the default startup or an attached .blend file (as simple as possible)] [alembic flicker hair.zip](https://archive.blender.org/developer/F7612371/alembic_flicker_hair.zip)
Author
Added subscriber: @CarlosPuebla
Member
Added subscriber: @lichtwerk
Member
It is still rendering, but I assume this is the same as #63534
Member
Looks like these are the same issues as in #63534, I will merge this report into the existing one...
Member
Closed as duplicate of #63534
2 Participants
Reference: blender/blender#67038
