Particle Instance from interpolated children works unexpected
Confirmed, NormalPublicKNOWN ISSUE
Operating system: win10 74bit
Broken: 2.8, 2.79b
"Children" option works good only with "Along path". Otherwise it just duplicates extra geometry where parent particles are located.
Open file and enable "Children" option, see how poly count is changed without visual appearance. Then check both "Children" and "Along Path" to see the difference.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Jul 18 2019, 11:33 AM
Can confirm.
This is another problem with interpolated children (simple children work fine here...)
Will check further...
Philipp Oeser (lichtwerk) renamed this task from Particle Instance from children works unexpected to Particle Instance from interpolated children works unexpected.Jul 18 2019, 11:33 AM
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Known Issue".
