Images as planes missing Eevee alpha channel support #67239
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#67239
Operating system: Windows 10
Graphics card: GTX970m
Broken: 2.80rc2
When using "import Image as Plane" in EEVEE, alpha channel is black, not transparent.
Switch to EEVEE, use function "import Image as Plane", choose any PNG file
Added subscriber: @Ruslan-Zhukovskyi
Added subscriber: @sigma.17-1
Added subscriber: @BrendonMurphy
hi, to enable transparency in eevee engine you need to go to Properties > Materials > Settings > and change the blend mode to Alpha Blend. This works with a valid Alpha .png
Changed status from 'Resolved' to: 'Open'
Re-opening, whilst not technically a bug, the addon should have checks for eevee/cycles and activate the alpha blend mode if eevee is the render engine. As it does not work as expected atm, this could be considered a bug.
EEVEE - alpha channel supportto Images as planes missing Eevee alpha channel supportAdded subscriber: @pioverfour
I don’t think the add-on should check for the render engine. If the user imports an image while the current render engine is Cycles, and then switch to Eevee, they’d expect the image to behave the same. Besides, the material setting is ignored by other render engines, so it should be okay to set it anyway.
This issue was referenced by
0f5738d902
Committed in
0f5738d902
