UV Edit Mode: using L or Ctrl+L to select individual islands does not work on mirrored uv islands that have any superimposed edge vertices.
Closed, InvalidPublic
Operating system: Windows-10-10.0.16299 64 Bits
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash: rB38d4483c6a51
When editing UV's, If you are mirroring UV's, If any shared vertex on the edge of the islands are exactly on top of one another. Using L or ctrl+L on any vertex of the island wll select both islands
**Exact steps for others to reproduce the error**
  • Add a UV Sphere.
  • Mark a seam down the middle to get 2 seperate islands
  • Unwrap UV
  • Select one of the two islands and scale it -1 on the x axis
  • Drag any edge vertex onto it's shared vertex on the other island. Select both shared edge vertex's and scale 0 to ensure precise stacking.
  • --> Now Trying to select either island using L or by selecting a vertex and using CTRL-L will select both islands.
  • Disabling sticky selection shared location doesn't change anything
A workaround can be to make selection in 3D View. In Face Select mode in 3D View, select linked is limited by UVseam.
Thank you, I just tried your workaround and can confirm that it works. Much appreciated.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jul 22 2019, 2:49 PM
This is just how it works currently, what is an island is based on vertex and edges being in the same location.
It could be improved once, but not considered a bug.
