Alpha Channel of Base Color in PBSDF Shader shows strange behavior #67327
Reference: blender/blender#67327
Broken: master
Setting an Alpha value for the Base Color of the PBSDF Shader results in strange behavior in eevee and is fully ignored in Cycles
I would expect that both planes show similar behavior, but it appears to me as if:
Also it seems like once you have added alpha to the Base color, the object continues to look strange even when you set the Base node alpha back to 1.0. You can see the strange viewport display best with the 2 cubes in the back. It appears to me like there is a normals issue. But the normals seem OK.
Added subscriber: @GaiaClary
Added subscriber: @brecht
Hi, @brecht This issue may be is related to https://developer.blender.org/T62794 ?
Added subscriber: @christian
There is an additional issue around that I think: alpha blend mode make transparency even if alpha value is 1 (Alpha entry, not the one of BaseColor). But it seems to respond correctly to an alpha < 1.
So changing alpha on BaseColor only 'seems' to have an effect due to that.
Additionally, the tooltip on 'alpha blend' says: "render polygon transparent depending on alpha channel of the texture"... so do we expect the alpha of BaseColor to work (it is not apparently) of the one from the Alpha input?
Closed as duplicate of #62794
