Cycles smoke has blocky shapes inside #67356
Closed
opened 2019-07-21 01:56:25 +02:00 by Steve Ernst · 18 comments
Operating system: Windows 10
Graphics card: 2x GeForce GTX 660 TI
Broken: 2.80 Release Candidate 2
Worked: 2.79
Blocky shapes and lines visible inside smoke when rendering with Cycles.
Create a smoke sim from particles and set up shader. When increasing density in the shader, strange blocky shapes and lines become apparent inside the smoke (rotating the view may help you see them better). These are NOT the typical artifacts from adaptive domain - these look more like shadows inside the smoke. I'm including an example file. smoke_blocky_bug.blend
**System Information** Operating system: Windows 10 Graphics card: 2x GeForce GTX 660 TI **Blender Version** Broken: 2.80 Release Candidate 2 Worked: 2.79 **Short description of error** Blocky shapes and lines visible inside smoke when rendering with Cycles. **Exact steps for others to reproduce the error** Create a smoke sim from particles and set up shader. When increasing density in the shader, strange blocky shapes and lines become apparent inside the smoke (rotating the view may help you see them better). These are NOT the typical artifacts from adaptive domain - these look more like shadows inside the smoke. I'm including an example file. [smoke_blocky_bug.blend](https://archive.blender.org/developer/F7621168/smoke_blocky_bug.blend)
Author
Added subscriber: @steveernst117
Added subscriber: @ZedDB
The result seems to be the same for me in 2.79 and 2.8.
Please retry with the latest beta build from here: https://builder.blender.org/download/
Is the result different if you use CPU rendering?
The result seems to be the same for me in 2.79 and 2.8. Please retry with the latest beta build from here: https://builder.blender.org/download/ Is the result different if you use CPU rendering?
Author
No, with CPU the result is the same.
I tried it with the newest build as you suggested, but still got the same problem. I'm including a screen grab so you can see what I'm getting.
No, with CPU the result is the same. I tried it with the newest build as you suggested, but still got the same problem. I'm including a screen grab so you can see what I'm getting. ![blender_smoke_bug.PNG](https://archive.blender.org/developer/F7626773/blender_smoke_bug.PNG) ![Inkedblender_smoke_bug.jpg](https://archive.blender.org/developer/F7626776/Inkedblender_smoke_bug.jpg)
I get the same thing with the latest 2.79 build:
But you don't get this with 2.79 release?
I get the same thing with the latest 2.79 build: ![screenshot.png](https://archive.blender.org/developer/F7626779/screenshot.png) But you don't get this with 2.79 release?
Author
No, my build of 2.79 is older. Splash screen says it was built on 2018-03-22. Guess I forgot to get a newer one.
But you can 100% confirm that this doesn't happen with the older release?
Author
I can confirm. Here's a screengrab of the result I get in my 2.79 build.
I can confirm. Here's a screengrab of the result I get in my 2.79 build. ![smoke_2.79.PNG](https://archive.blender.org/developer/F7626802/smoke_2.79.PNG)
Brecht Van Lommel was assigned by Sebastian Parborg 2019-07-24 18:16:30 +02:00
Added subscriber: @dark999
this is pretty strange i save newly this test file and then i reopen in on 1 month old blender, smoke simulaed have difference, same frame 36
Screenshot_20190724_180714.png Screenshot_20190724_181053.png Screenshot_20190724_182239.png
all this on linux Blender 2.80-19aa873f7002 (2019-07-23) AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 430.34
this is pretty strange i save newly this test file and then i reopen in on 1 month old blender, smoke simulaed have difference, same frame 36 ![Screenshot_20190724_180714.png](https://archive.blender.org/developer/F7626816/Screenshot_20190724_180714.png) ![Screenshot_20190724_181053.png](https://archive.blender.org/developer/F7626814/Screenshot_20190724_181053.png) ![Screenshot_20190724_182239.png](https://archive.blender.org/developer/F7626822/Screenshot_20190724_182239.png) all this on linux Blender 2.80-19aa873f7002 (2019-07-23) AMD FX8350, 16GB DDR3, GTX690 2+2 GB VRam- Nvidia drivers 430.34
Added subscriber: @comvico
Same here. In addition the shadows appear broken. WIN 10 Blender 2.8 stable
Same here. In addition the shadows appear broken. WIN 10 Blender 2.8 stable ![Anmerkung 2019-10-01 195259.jpg](https://archive.blender.org/developer/F7783818/Anmerkung_2019-10-01_195259.jpg)
Added subscriber: @Beaug
Both stable 2.8 and beta 2.81 have blocky shadows:
Is there a date when this will be fixed? Otherwise, I have to go back to 2.79 for VFX production, which is fine :).
Both stable 2.8 and beta 2.81 have blocky shadows: 2.8 ![ACES_explosion_test_IMG.0015.png](https://archive.blender.org/developer/F7958620/ACES_explosion_test_IMG.0015.png) 2.81 ![b281_blocky_shadows_v001.png](https://archive.blender.org/developer/F7958629/b281_blocky_shadows_v001.png) Is there a date when this will be fixed? Otherwise, I have to go back to 2.79 for VFX production, which is fine :).
Brecht Van Lommel was unassigned by Dalai Felinto 2019-12-23 16:33:37 +01:00
Added subscriber: @brecht
Added subscriber: @mano-wii
Germano Cavalcante self-assigned this 2020-02-06 18:58:52 +01:00
I updated the file to work inmantaflow.
Here is the result on Eevee:
Here is the result in Cycles:
The result seems to be matching.
That "lines" in Cycles' smoke is an effect of the chosen "Step Size" (0.1 by default).
It's not a bug -> https://docs.blender.org/manual/en/dev/render/cycles/render_settings/volumes.html
Closing then.
I updated the file to work inmantaflow. Here is the result on Eevee: ![image.png](https://archive.blender.org/developer/F8325915/image.png) Here is the result in Cycles: ![image.png](https://archive.blender.org/developer/F8325918/image.png) The result seems to be matching. That "lines" in Cycles' smoke is an effect of the chosen "Step Size" (0.1 by default). It's not a bug -> https://docs.blender.org/manual/en/dev/render/cycles/render_settings/volumes.html Closing then.
7 Participants
Reference: blender/blender#67356
