Keyframes for material animations don't appear #67359
Closed
opened 2019-07-21 03:14:02 +02:00 by Jane · 7 comments
Operating system: Windows 10 x64
Graphics card: GTX 1080
Broken: 2.80 beta Hash: 5f140e61c2
When I animate values in the Mapping node, no keyframes appear in the timeline, graph editor or dope sheet.
It would be great to have this working so I can do things like sprite animation, or add modifiers to make material animations loop.
It also appears that animating other values in Shader Editor also don't result in a keyframe being visible in timeline, graph editor or dope sheet.
  1. Load a single image on a plane (using import images as planes)
  2. Switch to rendered or lookdev view to see the image
  3. Connect a mapping node and texture coordinate node to image texture in Shader Editor
  4. Insert 2 different keyframes on the mapping node location value to animate
I have an example of a blinking sign here made using same steps as above:
material animation.blend
**System Information** Operating system: Windows 10 x64 Graphics card: GTX 1080 **Blender Version** Broken: 2.80 beta Hash: 5f140e61c28c **Short description of error** When I animate values in the Mapping node, no keyframes appear in the timeline, graph editor or dope sheet. It would be great to have this working so I can do things like sprite animation, or add modifiers to make material animations loop. It also appears that animating other values in Shader Editor also don't result in a keyframe being visible in timeline, graph editor or dope sheet. **Exact steps for others to reproduce the error** 1. Load a single image on a plane (using import images as planes) 2. Switch to rendered or lookdev view to see the image 3. Connect a mapping node and texture coordinate node to image texture in Shader Editor 4. Insert 2 different keyframes on the mapping node location value to animate I have an example of a blinking sign here made using same steps as above: [material animation.blend](https://archive.blender.org/developer/F7621229/material_animation.blend)
Author
Added subscriber: @adelruna
Member
Added subscriber: @EAW
Member
I just figured it out. I have had this annoying issue previously, but didn't work out the particulars until now.
The setting to view "Only Selected" turnoff only selcted.jpg is on in the dopesheet and (by default in most cases as far as I can tell). If you click it off, turnoff only selcted.jpg the key frames will appear. The option to turn it off is in the timeline's view menu. timelinemenu.jpg When it is on, you have to select both the object and the node inorder for the keyframes to appear. bothselectedv2.jpg
without the other results in the keyframes staying hidden.
The behavior is identical to 2.79b, so it isn't a regression
It would be nice if "only selected" was off by default in the shading editor, as to not confuse new users.
I just figured it out. I have had this annoying issue previously, but didn't work out the particulars until now. The setting to view "Only Selected" ![turnoff only selcted.jpg](https://archive.blender.org/developer/F7621264/turnoff_only_selcted.jpg) is on in the dopesheet and (by default in most cases as far as I can tell). If you click it off, ![turnoff only selcted.jpg](https://archive.blender.org/developer/F7621274/turnoff_only_selcted.jpg) the key frames will appear. The option to turn it off is in the timeline's view menu. ![timelinemenu.jpg](https://archive.blender.org/developer/F7621285/timelinemenu.jpg) When it is on, you have to select both the object and the node inorder for the keyframes to appear. ![bothselectedv2.jpg](https://archive.blender.org/developer/F7621272/bothselectedv2.jpg) Selecting only the object ![objectonly selected.jpg](https://archive.blender.org/developer/F7621278/objectonly_selected.jpg) or the node ![mapping node selected without object.jpg](https://archive.blender.org/developer/F7621280/mapping_node_selected_without_object.jpg) without the other results in the keyframes staying hidden. The behavior is identical to 2.79b, so it isn't a regression It would be nice if "only selected" was off by default in the shading editor, as to not confuse new users.
Author
Wow thanks for the quick response, I am really grateful!
Having to select the node and the object is quirky but it works. Perhaps it can be documented officially somewhere?
Wow thanks for the quick response, I am really grateful! Having to select the node and the object is quirky but it works. Perhaps it can be documented officially somewhere?
Brecht Van Lommel self-assigned this 2019-07-22 11:39:03 +02:00
Added subscriber: @altesc-2
Thank you for this!
Thank you for this!
Reference: blender/blender#67359
