Material button crash bug #67466
2 Participants
Reference: blender/blender#67466
Operating system: windows professional service pack 1
Graphics card: NVIDIA Quadro 1000M
Broken: The last few releases. Now doing it in Blender2.80Cr2
Worked: 2.79 still works fine.
Crash
start blender - click material button - crash
Debug file
Switching to fully guarded memory allocator.
Blender 2.80 (sub 74)
Build: Thu 07/11/2019 09:59 AM Windows
argv- [x] = blender
argv- [x] = --debug
argv- [x] = --debug-gpu
argv- [x] = --python-expr
argv- [x] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\Admin\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
Read prefs: C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
read file
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Texture state usage warning: Waste of memory: Texture 0 has mipmaps, while its min filter is inconsistent with mipmaps.
GL API other: Texture state usage warning: Texture 0 is base level inconsistent. Check texture size.
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), and GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GL API other: Buffer detailed info: Buffer object 1 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), and GL_ARRAY_BUFFER_ARB, usage hint is GL_DYNAMIC_DRAW) has been mapped WRITE_ONLY in SYSTEM HEAP memory (fast).
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (2), and GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operations.
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (2), and GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object operationsGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: TeGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: Texture state usage warning: Waste of memory: Texture 0 has mipmaps, while its min filter is inconsistent GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
with mipmaps.
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (2), and GL_ARRAY_BUFFER_AGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL AGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: Texture state usage warning: Waste of memory: Texture 0 has mipmGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (0), GL_VERTEX_ATTRIB_ARRAY_BUFFER_BINDING_ARB (1), GL_VERTEX_ATTRIB_ARRAY_BUFGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: Texture state usage warning: Waste of memory: Texture 0 has mipmaps, while its minGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_VGPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GL API other: Texture state usage warning: Waste of memory: Texture 0 has mipmGPUTexture: create : TEXTURE_2D, RGBA8, w : 407, h : 170, d : 0, comp : 4, size : 0.26 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 128, d : 0, comp : 1, size : 2.00 MiB
GL API othread file
read file
GL API other: Buffer detailed info: Buffer object 2 (bound to GL_ARRAY_BUFFER_ARB, usage hint is GL_STREAM_DRAW) will use VIDEO memory as the source for buffer object GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 32, h : 32, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA32F, w : 32, h : 32, d : 0, comp : 4, size : 0.03 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 16, h : 16, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RG16F, w : 16, h : 16, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA32F, w : 32, h : 16, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, R32F, w : 32, h : 16, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 32, h : 32, d : 0, comp : 3, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 32, h : 32, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, RG16I, w : 16, h : 16, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R16F, w : 16, h : 16, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 16, h : 16, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 32, h : 32, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA16F, w : 64, h : 64, d : 20, comp : 4, size : 1.25 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 64, h : 64, d : 0, comp : 4, size : 0.06 MiB
GPUTexture: create : TEXTURE_1D, RG16F, w : 1024, h : 0, d : 0, comp : 2, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA8, w : 32, h : 32, d : 129, comp : 4, size : 0.50 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, R11F_G11F_B10F, w : 628, h : 628, d : 2, comp : 3, size : 3.01 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, R8, w : 1, h : 1, d : 1, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_CUBE_MAP, DEPTH_COMPONENT24, w : 512, h : 512, d : 0, comp : 1, size : 4.50 MiB
GPUTexture: create : TEXTURE_CUBE_MAP, RG32F, w : 512, h : 512, d : 0, comp : 2, size : 24.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RG32F, w : 1255, h : 1255, d : 2, comp : 2, size : 48.07 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, DEPTH_COMPONENT24, w : 1024, h : 1024, d : 4, comp : 1, size : 12.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RG32F, w : 1024, h : 1024, d : 4, comp : 2, size : 64.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, RG32F, w : 1024, h : 1024, d : 1, comp : 2, size : 16.00 MiB
GPUTexture: create : TEXTURE_2D_ARRAY, DEPTH_COMPONENT24, w : 1, h : 1, d : 1, comp : 1, size : 0.00 MiB
operations.
GPUShaderInterface: Warning: Uniform 'attr' not found!
GPUShaderInterface: Warning: Uniform 'hairPointBuffer' not found!
GPUShaderInterface: Warning: Uniform 'hairUVBuffer' not found!
GPUShaderInterface: Warning: Uniform 'hairColBuffer' not found!
GPUShaderInterface: Warning: Uniform 'colorBuffer' not found!
GPUShaderInterface: Warning: Uniform 'depthBuffer' not found!
GPUShaderInterface: Warning: Uniform 'minzBuffer' not found!
GPUShaderInterface: Warning: Uniform 'planarDepth' not found!
GPUShaderInterface: Warning: Uniform 'texHammersley' not found!
GPUShaderInterface: Warning: Uniform 'texJitter' not found!
GPUShaderInterface: Warning: Uniform 'sssTexProfile' not found!
GPUShaderInterface: Warning: Uniform 'inScattering' not found!
GPUShaderInterface: Warning: Uniform 'inTransmittance' not found!
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00000000691113E0
Module : C:\Windows\system32\nvoglv64.DLL
Blender_system_info
Blender 2.80 (sub 74) System Information
Blender:
version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash:
06312c6d2d
, type:build date: Thu 07/11/2019, 09:59 AM
platform: Windows
binary path: 'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\blender.exe'
build cflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP -openmp
build cxxflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc -openmp
build linkflags: /MACHINE:X64 /SUBSYSTEM:CONSOLE /STACK:2097152 /INCREMENTAL:NO /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Python:
version: 3.7.0 (default, Aug 26 2018, 16:05:01) [MSC v.1900 64 bit (AMD64)]
paths:
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons_contrib'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\startup'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\modules'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\python37.zip'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\python\DLLs'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\python\lib'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\python'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\python\lib\site-packages'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\freestyle\modules'
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\modules'
'C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\modules'
Python (External Binary):
binary path: 'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\python\bin\python.EXE'
version: Python 3.7.0
Directories:
scripts:
'C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts'
user scripts: 'C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\2.80\scripts'
pref scripts: None
datafiles: 'C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\2.80\datafiles\'
config: 'C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\2.80\config\'
scripts : 'C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\'
autosave: 'C:\Users\Admin\AppData\Roaming\Blender Foundation\Blender\2.80\autosave\'
tempdir: 'C:\Users\Admin\AppData\Local\Temp\blender_a07120\'
FFmpeg:
avcodec: '58, 18, 100'
avdevice: '58, 3, 100'
avformat: '58, 12, 100'
avutil: '56, 14, 100'
swscale: ' 5, 1, 100'
SDL:
Version: 2.0.8
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
OpenColorIO: 1, 1, 0
OpenImageIO: 1, 8, 13
OpenShadingLanguage: 1, 9, 9
OpenSubdiv: 0, 0, 0
OpenVDB: 5, 1, 0
Alembic: 1, 7, 8
OpenGL:
renderer: 'Quadro 1000M/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.3.0'
extensions:
GL_AMD_multi_draw_indirect
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_clear_buffer_object
GL_ARB_color_buffer_float
GL_ARB_compressed_texture_pixel_storage
GL_ARB_compute_shader
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXTX_framebuffer_mixed_formats
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_import_sync_object
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_store
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug
GL_KTX_buffer_region
GL_NVX_conditional_render
GL_NVX_gpu_memory_info
GL_NV_ES1_1_compatibility
GL_NV_bindless_multi_draw_indirect
GL_NV_blend_square
GL_NV_compute_program5
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_draw_texture
GL_NV_explicit_multisample
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_gpu_program4_1
GL_NV_gpu_program5
GL_NV_gpu_program5_mem_extended
GL_NV_gpu_program_fp64
GL_NV_gpu_shader5
GL_NV_half_float
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_atomic_counters
GL_NV_shader_atomic_float
GL_NV_shader_buffer_load
GL_NV_shader_storage_buffer_object
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control
Implementation Dependent OpenGL Limits:
Maximum DrawElements Vertices: 1048576
Maximum DrawElements Indices: 1048576
GLSL:
Maximum Varying Floats: 124
Maximum Vertex Attributes: 16
Maximum Vertex Uniform Components: 4096
Maximum Fragment Uniform Components: 2048
Maximum Vertex Image Units: 32
Maximum Fragment Image Units: 32
Maximum Pipeline Image Units: 192
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41 AVX
OpenCL device capabilities:
Number of platforms: 1
Platform #0
Platform Name: NVIDIA CUDA
Platform Vendor: NVIDIA Corporation
Platform Version: OpenCL 1.1 CUDA 4.2.1
Platform Profile: FULL_PROFILE
Platform Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_d3d9_sharing cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll
Number of devices: 1
Device: #0
Device Name: Quadro 1000M
Device Vendor: NVIDIA Corporation
Device OpenCL C Version: OpenCL C 1.1
Device Profile: FULL_PROFILE
Device Version: OpenCL 1.1 CUDA
Device Extensions: cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_d3d9_sharing cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64
Device Max clock frequency (MHz): 1400
Device Max compute units: 2
Device Max work group size: 1024
CUDA device capabilities:
Quadro 1000M
CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_BLOCK 1024
CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_X 1024
CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Y 1024
CU_DEVICE_ATTRIBUTE_MAX_BLOCK_DIM_Z 64
CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_X 65535
CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Y 65535
CU_DEVICE_ATTRIBUTE_MAX_GRID_DIM_Z 65535
CU_DEVICE_ATTRIBUTE_MAX_SHARED_MEMORY_PER_BLOCK 49152
CU_DEVICE_ATTRIBUTE_SHARED_MEMORY_PER_BLOCK 49152
CU_DEVICE_ATTRIBUTE_TOTAL_CONSTANT_MEMORY 65536
CU_DEVICE_ATTRIBUTE_WARP_SIZE 32
CU_DEVICE_ATTRIBUTE_MAX_PITCH 2147483647
CU_DEVICE_ATTRIBUTE_MAX_REGISTERS_PER_BLOCK 32768
CU_DEVICE_ATTRIBUTE_REGISTERS_PER_BLOCK 32768
CU_DEVICE_ATTRIBUTE_CLOCK_RATE 1400000
CU_DEVICE_ATTRIBUTE_TEXTURE_ALIGNMENT 512
CU_DEVICE_ATTRIBUTE_GPU_OVERLAP 1
CU_DEVICE_ATTRIBUTE_MULTIPROCESSOR_COUNT 2
CU_DEVICE_ATTRIBUTE_KERNEL_EXEC_TIMEOUT 1
CU_DEVICE_ATTRIBUTE_INTEGRATED 0
CU_DEVICE_ATTRIBUTE_CAN_MAP_HOST_MEMORY 1
CU_DEVICE_ATTRIBUTE_COMPUTE_MODE 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_HEIGHT 65535
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_WIDTH 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_HEIGHT 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LAYERED_LAYERS 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_WIDTH 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_HEIGHT 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_ARRAY_NUMSLICES 2048
CU_DEVICE_ATTRIBUTE_SURFACE_ALIGNMENT 512
CU_DEVICE_ATTRIBUTE_CONCURRENT_KERNELS 1
CU_DEVICE_ATTRIBUTE_ECC_ENABLED 0
CU_DEVICE_ATTRIBUTE_TCC_DRIVER 0
CU_DEVICE_ATTRIBUTE_MEMORY_CLOCK_RATE 900000
CU_DEVICE_ATTRIBUTE_GLOBAL_MEMORY_BUS_WIDTH 128
CU_DEVICE_ATTRIBUTE_L2_CACHE_SIZE 131072
CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_MULTIPROCESSOR 1536
CU_DEVICE_ATTRIBUTE_ASYNC_ENGINE_COUNT 1
CU_DEVICE_ATTRIBUTE_UNIFIED_ADDRESSING 1
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_WIDTH 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LAYERED_LAYERS 2048
CU_DEVICE_ATTRIBUTE_CAN_TEX2D_GATHER 1
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_WIDTH 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_GATHER_HEIGHT 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_WIDTH_ALTERNATE 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_HEIGHT_ALTERNATE 0
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE3D_DEPTH_ALTERNATE 0
CU_DEVICE_ATTRIBUTE_TEXTURE_PITCH_ALIGNMENT 32
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_WIDTH 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_WIDTH 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURECUBEMAP_LAYERED_LAYERS 2046
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_HEIGHT 32768
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_HEIGHT 32768
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE3D_DEPTH 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE1D_LAYERED_LAYERS 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_WIDTH 65536
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_HEIGHT 32768
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACE2D_LAYERED_LAYERS 2048
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_WIDTH 32768
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_WIDTH 32768
CU_DEVICE_ATTRIBUTE_MAXIMUM_SURFACECUBEMAP_LAYERED_LAYERS 2046
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_LINEAR_WIDTH 134217728
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_WIDTH 65000
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_HEIGHT 65000
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_LINEAR_PITCH 1048544
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_WIDTH 16384
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE2D_MIPMAPPED_HEIGHT 16384
CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MAJOR 2
CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MINOR 1
CU_DEVICE_ATTRIBUTE_MAXIMUM_TEXTURE1D_MIPMAPPED_WIDTH 16384
CU_DEVICE_ATTRIBUTE_STREAM_PRIORITIES_SUPPORTED 0
Enabled add-ons:
io_scene_fbx (version: (4, 14, 14), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_scene_fbx_init_.py)
io_anim_bvh (version: (1, 0, 0), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_anim_bvh_init_.py)
io_mesh_ply (version: (1, 0, 0), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_mesh_ply_init_.py)
io_scene_obj (version: (3, 5, 9), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_scene_obj_init_.py)
io_scene_x3d (version: (2, 2, 1), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_scene_x3d_init_.py)
io_mesh_stl (version: (1, 1, 3), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_mesh_stl_init_.py)
io_mesh_uv_layout (version: (1, 1, 1), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_mesh_uv_layout_init_.py)
io_curve_svg (version: UNKNOWN, path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_curve_svg_init_.py)
cycles (version: UNKNOWN, path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\cycles_init_.py)
io_scene_gltf2 (version: (0, 9, 35), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\io_scene_gltf2_init_.py)
add_curve_extra_objects (version: (0, 1, 3), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\add_curve_extra_objects_init_.py)
add_mesh_extra_objects (version: (0, 3, 3), path: C:\Users\Admin\Downloads\blender-2.80rc1-windows64\blender-2.80rc1-windows64\2.80\scripts\addons\add_mesh_extra_objects_init_.py)
Added subscriber: @BrandonChrisjohn
Added subscriber: @brecht
This graphics driver version is too old, please ensure you have installed the latest drivers from the NVIDIA website.
