Blender freeze after few renders .
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 398.36
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-22 11:13, hash: rB02c5c091dfd6
[After 3, ,5 or more renders blender freeze and not response, and you can only close it via Task Manager ]
[1) set in menu render/display mode/keep user interface
  1. Go to rendering work space or to shading work space ]
  2. press f12 for render . wait until it finish render .
  3. press f12 again . Continue this step 3 or more times , and it will freeze blender. Some times need more than 10 times before it will freeze.
on linux Blender 2.80-19aa873f7002 (2019-07-23) AMD FX8350, 16G ram, GTX690 - Nvidia drivers 340.34
if i render from Lock Dev or Rendered viewport shading i have a 'CUDA error: out of memory' with a simple startup scene, i presume with 3GB is still same.
my GTX690 has 2+2GB VRam
Sebastian Parborg (zeddb) lowered the priority of this task from Needs Triage by Developer to Waiting for Developer to Reproduce.
Brecht Van Lommel (brecht) lowered the priority of this task from Waiting for Developer to Reproduce to Needs Information from User.EditedWed, Sep 25, 4:55 PM
I can't reproduce this issue. NVIDIA driver versions 398.36 and definitely 340.34 are quite old. Newer drivers have bugfixes that may help, so please test with the latest drivers from the NVIDIA website.
Since I haven't seen similar reports about Blender freezing with CUDA, I suspect it's something specific about this system setup, and the older driver versions may be it.
Also please try the latest Blender daily build.
https://builder.blender.org/download/
Closing due to lack of information to investigate the issue further, we can reopen the report if more information is provided.
