Color picker eyedropper button not working from a popover
Closed, DuplicatePublic
Graphics card: AMD Radeon(TM) Vega 10 Mobile Graphics ATI Technologies Inc. 4.5.13542 Core Profile Context 25.20.14016.1
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-18 14:52, hash: rB38d4483c6a51
GREASEPENCIL
Go to the material menu and click on select color. There's a eyedropper button for selecting a color, but it doesn't work.
OR VIEWPORT SHADING
  • Open the shading popover, switch to "Single" mode, click on the color "slot", then click on the eyedropper button... Nothing happens. (the eyedropper doesn't show up)
  • -Try to change the outline color with the color picker (it doesn't work with object color or background color either.)
Stephen Swaney (stiv) lowered the priority of this task from 90 to 30.Jul 24 2019, 2:54 AM
Choosing colors via the eyedropper from Properties->Material works. Are you trying to change the color from the dropdown in the header rather than the Properties panel?
From the manual:
Grease Pencil Materials can be created in the Material properties as any other materials in Blender.
Can you try with a newer release, like the RC2 version?
Yes, sorry, I am talking about the dropdown menu from the header. When using the material tab on the properties panel I don't have this problem.
I am using the rc2 version right now and I've tried the latest build before posting the bug.
Stephen Swaney (stiv) lowered the priority of this task from 30 to Low.Jul 25 2019, 3:53 PM
Thanks. Changing color from the drop-down doesn't work.
I'm not sure if that is intended behavior. It seems a bit redundant since you can pick colors from the Material panel.
If so, you shouldn't be able to pop up a color picker.
We'll have to get a ruling from the judges.
Philipp Oeser (lichtwerk) renamed this task from Eyedropper button on color select menu doesn't work to Color picker eyedropper button not working from a popover.Sep 2 2019, 9:45 AM
