3Dcoat applink has a bug
Closed, InvalidPublic
the model is scaled up by 100, but in the transform it has a delta of .001 (which equal 1)
this means if you try to apply the transform in blender the model will get tiny since only the transform is applied and the delta is left.
Graphics card: GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-11 13:50, hash: rB06312c6d2db8
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/wiki/Process/Bug_Reports
Bastien Montagne (mont29) closed this task as Invalid.
