Point density texture crashes
Closed, ResolvedPublicBUG
Graphics card: AMD Radeon(TM) Vega 8 Graphics ATI Technologies Inc. 4.5.13558 Core Profile Context 26.20.11015.5009
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: rB507ffee6e1f4
using point density texture in cycles always crashes while tweaking the settings
open blender,
select cycles as the renderer,
add a particle on the cube,
use point density in shader nodes,
tweak some point density settings,
and it crashes
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 50.
@Brecht Van Lommel (brecht), node->typeinfo sometimes is NULL.
Here is a file to reproduce the problem:
Can confirm this on 2.81 hash: 970d7ed860f1
Windows 10 64 bits
Intel i5-6500
NVidia GTX 1060
Germano Cavalcante (mano-wii) changed the subtype of this task from "Report" to "Bug".Jan 24 2020, 7:17 PM
Brecht Van Lommel (brecht) triaged this task as High priority.Feb 18 2020, 11:06 AM
I think the issue is that the builtin_data parameter to builtin_image_float_pixels is sometimes a ID * and sometimes a bNode *. Currently, the function has no way to determine which pointer type it is afaik. The problem is that RNA_id_pointer_create((ID *)builtin_data, &ptr); is called even if builtin_data is actually a pointer to a node.
I don't really know at which level this should be fixed...
