Child of constraint target bug #67729
Reference: blender/blender#67729
Broken: pretty sure till the latest Release Candidate build
Worked: ???
I have seen this bug for quite a long time, and I'm still surprised that it hasn't been noticed by the developers for such long time.
If you try to change the parent target inside of the child of constraint, then clicking "set inverse" will no longer work properly.
Get three objects in your scene.
Here's what you do:
The first object will move in an unknown location as expected so you would have to set inverse again.
Unfortunately tho, the object will go in an unknown location aswell when you click set inverse.
The only way to fix it is by removing the constraint from the first object and make a new one, and this time directly make the third object as the parent target, when you set inverse, the object will go back to its original position just fine.
So what is this bug that confuses the software to do such thing?
This problem applies to bones aswell
Added subscriber: @Maker26
Added subscriber: @dark999
You forgot to upload a simplest possible .blend file to reproduce this issue
Please, update this report following strictly this form https://developer.blender.org/maniphest/task/edit/form/1/
The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this issue
Check if you hardware and OS work properly outside Blender use and if they have latest update
Next time you can use Help > Report a Bug item and striclty follow this form. Attach a simplest possible .blend file, before you made a bugreport you must search if bug/issue is already reported from others users
You can check here https://www.blender.org/download/requirements/ if your hardware and software meet minimum Blender requirement, if not, you can consider this report as invalid until Blender developers validate this issue
thank you
Added subscriber: @Mets
I don't think things like GPU and drivers are likely to be the cause of this issue. And I think they followed the submission form reasonably well. :)
That said, I couldn't reproduce this, so a blend file would definitely be welcome. I recall sometimes having this issue with bones, but even then, hitting Clear Inverse and then Set Inverse fixed it. Here's the .blend where I tried reproducing the issue, but I couldn't:
childof_worksfine.blend
@Mets if blender is open with unsupported hardware and software all kind of error, issues and bugs can be see
how you know user specific of hardware him use?
Huh, weird, it works fine for me aswell.... for objects only.
but you might have not read the text clearly
"This problem applies to bones aswell"
So, if this doesn't occur with objects, then it should occur with bones instead.
Here is the blend file:
childof With bones.blend
The first target is already set, YOU must change that target bone to the "Second Target" (I named it so you would know which one it is)
I also made a original location for the main bone so you would also know where that bone is supposed to stay normally
Edit: The original location is a bone named "LocationForMainBone"
Edit2: Make sure you are using the latest build. The release candidate build
True, knowing your OS and hardware can't hurt. And I'm all for enforcing stricter rules on bug reports :P But my gut tells me all we need to get to the bottom of this one is a blend file.
Edit: And as I was typing that we got one! Checking...
Added subscriber: @WilliamReynish
Cannot reproduce any issues.
I can see the issue, but it does go away after hitting Clear Inverse.
In the provided blend file, change the Child Of target to "Second target" and hit Set Inverse. It would be expected that the bone goes back to the location of "LocationForMainBone" but it does not. Hitting Clear Inverse then Set Inverse again will work though.
Not sure if a bug, or if you're expected to hit Clear Inverse by design for it to go back to its original place. Seems odd to me for sure.
@Maker26 You forgot to update this report following Strictly this form https://developer.blender.org/maniphest/task/edit/form/1/ as already request
So hitting "Clear Inverse" first and then "Set Inverse" would fix it. Alright, this should do the job.
This means that the bug has been solved and this topic is closed as solved :D
This means we found a workaround, and there might still be a bug here to fix ^^
A dev will hopefully come around eventually and decide.
Not a bug then? :P
