Control behaviour to deselect objects #67730
Reference: blender/blender#67730
Operating system: Mac Os 10.13.6
Graphics card: AMD Radeon HD 6970M 1024 MB
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash:
507ffee6e1
, type: Releasebuild date: 2019-07-24, 18:10:54
If I have a group of objects selected, when I'm using the standard selection tool and I press control to deselect just one object of the group, I got instead a selection of the last object I've clicked.
Create some objects, select them clicking Shift, pressing control to deselect one, instead just select the last one object.
Added subscriber: @aluxado
Added subscriber: @dark999
to deselect one or more object from many you must use Alt-key instead Shift-key, Ctrl-Click work as expected
Honestly, I've tried again but it doesn't work as you said. If I press also the Alt / Ctrl key on a single object I want to deselect from a group it just selects this last object. In this way, I lose the selection of the other objects I had.
with selecting tool active Box, Circle, Lazo
if you use Left Click Select mode
to add object on already select object you must press Shift-key and click Left mouse button and drag as you have wrote
to deselect one or more object from already selected you must use Alt-key and click Left mouse button and drag
Ctrl key and click Left mouse button on object make single selection on object
this work as expected an designed
Ok, sorry, thanks for the explanation. Coming from Modo it's just strange this behavior that I must drag with the Alt Key pressed instead of just clicking on the object you want to deselect, but I understand that is just as the software is designed! :) Thanks for the replies.
Added subscriber: @SpectreFirst
As far as I can see, default Blender keymap uses Shift+Click to do Toggle selection so you can select and deselect objects in the group (deselecting takes two clicks – one to make object active and one to deselect) while Ctrl+Click is used for “Select Center” and Alt+Click does “Enumerate” when there are several objects under the cursor. Box selection can deselect with Ctrl and add to selection with Shift. In any case, it shouldn’t be difficult to reassign these functions to your liking.
Thank you very much @SpectreFirst for the complete and helpful clarification! :)
with this selection tool you can only click over object to select and deselect using Shift to add and Alt to remove selction. I think you search this function
