Bottom Tool tip keybinds when in grab mode.
Graphics card: GeForce GTX 680/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: rB507ffee6e1f4
If you change the keybind for rotate/grab/scale it doens't update in the tooltip when you are in grab mode.
  1. Change the keybind for grab/scale/rotate
  2. Grab the model and the bottom tooltip will still say G/R/S even if you changed them to something else.
Those are part of the modal transform keys, which is different.
I'm not sure you can even change those at all?
@Campbell Barton (campbellbarton) Not technically a bug, but seems wrong if you cannot change those at all.
William Reynish (billreynish) triaged this task as Confirmed, Low priority.Jul 28 2019, 10:15 AM
You can change those, it's under the "Transform Modal Map" key binds. The bottom tooltip just doesn't seem to change, it's not a major issue but seems wrong since most of the other tooltips do change based on what keys you bind them to.
This is a more a TODO.
There are some keys not available in the modal map, once that's done the hard-coded keys can be removed.
