The "Spin" and "Screw" tools are not well implemented as classic operators
Open, Confirmed, MediumPublic
Graphics card: Intel(R) HD Graphics 4400 Intel 4.3.0 - Build 20.19.15.4549
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-26 15:34, hash: rB79ce2054d436
The "Spin" and "Screw" tools are not well implemented as classic operators and they are not included in the header bar menus. And the "Screw" tool is not available as an active tool.
#1.- The "Spin" and "Screw" tools both continue to exist and are found as classic operators by typing their names in the search option (F3), but they are not included in the header bar menus, and are not found in the bar and panel indicated in the Blender 2.80 User Manual, since this left sidebar of tools no longer exists as such in the new version.
#2.- Specific problems with the "Spin" operator:
· The "Spin" tool, executed as a classic operator (from the search, with F3), uses a default angle of rotation of 0º which causes confusion (while in version 2.79 a default angle of 90º is used).
· The "Spin" tool does not work with the Alt+R shortcut indicated in the Blender 2.80 User Manual: https://docs.blender.org/manual/en/dev/modeling/meshes/editing/duplicating/spin.html
#3.- Specific problems with "Screw" tool:
· The "Screw" tool is not available as an active tool.
https://docs.blender.org/manual/en/dev/modeling/meshes/editing/duplicating/screw.html
Spin tool is still here. 2.8 RC3
It does not since you use "new" or "industry compatible" keymap. And yes, it uses 0 degree spin as you've mentioned.
Yes, I know that "Spin" can be used as an "active tool", but the fact is that it does not exist in menus, or keyboard shortcuts, or any button as a "CLASSIC OPERATOR", while it is still in the Blender code but is only accessible in search F3.
However, "Screw" cannot even be used as an active tool, and either from menus or keyboard shortcut.
As for the keyboard shortcuts, what I mean is that, now, in addition to not finding those two tools as classic operators anywhere in the UI (only "Spin" as active tool), they cannot be accessed with any keyboard shortcut (I don't think the main problem is whether the shortcuts are an industry standard or not, but simply DO NOT HAVE KEYBOARD SHORTCUTS OR ALSO AND NEITHER THEY DON'T ARE ACCESSIBLE AS "CLASSIC OPERATORS" FROM NO PLACE OF THE INTERFACE, AND ONLY THEY ARE ACCESSIBLE SEARCHED FROM F3). The situation is that, if there is no accessibility of any kind (as in the case of "Screw"), something should be enabled ... I do not say that it must necessarily be a keyboard shortcut ... or maybe yes ... or an entry from menu ... whatever, but something!
And for greater confusion, not even the access to those tools indicated in the User Manual does not correspond to the reality of version 2.80
Sebastian Parborg (zeddb) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.Aug 1 2019, 6:11 PM
@Campbell Barton (campbellbarton) @William Reynish (billreynish) I'm guessing that these should be available in a menu somewhere?
