GPencil: Clone brush don't copy all layers
Operating system:windows 10
Graphics card:msi gtx 1050ti
Broken: Blender 2.80 Release Candidate 3
Clone, works well for the first copy
  But for the second copy, stroke turns it into fill!
And I'm having trouble drawing a circle with the Circle tool because it has to guess its size when drawing
Draw a circle with a stroke and select it in the Sculpt Mode section and then click Clone then you will find that the first copy is correct but the second copy is Fill
Antonio Vazquez (antoniov) renamed this task from Clone in Sculpt mode to GPencil: Clone brush don't copy all layers.Jul 29 2019, 10:32 PM
Antonio Vazquez (antoniov) claimed this task.
Antonio Vazquez (antoniov) lowered the priority of this task from 90 to Normal.
This is a limitation now... The problem is the first copy is using all layers, but the next clones only uses the active one.
