Hotkeys and Mouse not registering as inputs.
Closed, InvalidPublic
Below is the error code log.
Switching to fully guarded memory allocator.
Blender 2.80 (sub 75)
Build: 2019-07-24 10:05 AM Windows
argv[0] = blender
argv[1] = --debug
argv[2] = --debug-gpu
argv[3] = --debug-gpu-force-workarounds
argv[4] = --python-expr
argv[5] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\ahuls\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
Read prefs: C:\Users\ahuls\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
read file C:\Users\ahuls\AppData\Roaming\Blender Foundation\Blender\2.80\config\startup.blend
Version 280 sub 50 date 2019-03-18 21:39 hash d47f827019f2
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPU: Bypassing workaround detection.
GPU: OpenGL identification strings
GPU: vendor: ATI Technologies Inc.
GPU: renderer: AMD Radeon(TM) Vega 3 Graphics
GPU: version: 4.5.13570 Core Profile/Debug Context 19.7.3 26.20.13001.18009
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
Using OpenGL 4.3 debug facilities
GL application marker: Successfully hooked OpenGL debug callback.
found bundled python: C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\python
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 187, in register_module_call
  register()
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\scripts\startup\bl_operators\__init__.py", line 70, in register
  register_class(cls)
ValueError: register_class(...): already registered as a subclass
During handling of the above exception, another exception occurred:
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\__init__.py", line 81, in <module>
  main()
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\__init__.py", line 78, in main
  utils.load_scripts()
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 260, in load_scripts
  test_register(mod)
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 229, in test_register
  register_module_call(mod)
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 189, in register_module_call
  import traceback
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\python\lib\traceback.py", line 5, in <module>
  import linecache
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\python\lib\linecache.py", line 11, in <module>
  import tokenize
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\python\lib\tokenize.py", line 33, in <module>
  import re
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\python\lib\re.py", line 122, in <module>
  import enum
File "C:\Users\ahuls\Desktop\blender-2.80rc3-windows64\2.80\python\lib\enum.py", line 2, in <module>
  from types import MappingProxyType, DynamicClassAttribute
ImportError: cannot import name 'MappingProxyType' from 'types' (C:\Users\ahuls\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\types.py)
  register()
  register_class(cls)
File "<string>", line 1, in <module>
  main()
  test_register(mod)
  import traceback
  import linecache
  import tokenize
  import re
  import enum
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Edit Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Draw brush)'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Erase)'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Fill)'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Sculpt Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Face Mask'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Weight Paint Vertex Selection'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Pose'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Object Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Paint Curve'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Curve'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Image Paint'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Vertex Paint'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Weight Paint'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Sculpt'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Mesh'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Armature'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Metaball'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Lattice'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Particle'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Font'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Object Non-modal'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Frames'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap '3D View Generic'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap '3D View'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Window'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Screen'
GPUTexture: create : TEXTURE_2D, RGBA8, w : 961, h : 26, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 128, d : 0, comp : 1, size : 2.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 405, h : 26, d : 0, comp : 4, size : 0.04 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1366, h : 20, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 237, h : 26, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 419, d : 0, comp : 4, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 208, h : 419, d : 0, comp : 4, size : 0.33 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 237, h : 185, d : 0, comp : 4, size : 0.17 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 26, d : 0, comp : 4, size : 0.11 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 96, h : 604, d : 0, comp : 4, size : 0.22 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 630, d : 0, comp : 4, size : 2.71 MiB
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 1128, h : 630, d : 0, comp : 1, size : 5.42 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 257, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 256, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1128, h : 630, d : 0, comp : 3, size : 2.71 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1128, h : 630, d : 0, comp : 1, size : 2.71 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1128, h : 630, d : 0, comp : 2, size : 2.71 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 64, h : 64, d : 0, comp : 4, size : 0.06 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1128, h : 630, d : 0, comp : 1, size : 2.03 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1128, h : 630, d : 0, comp : 1, size : 1.36 MiB
GPUShaderInterface: Warning: Uniform 'viewportSize' not found!
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 64, d : 0, comp : 1, size : 1.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 527, h : 491, d : 0, comp : 4, size : 0.99 MiB
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Screen Editing'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'User Interface'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'View2D'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Region Context Menu'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'View2D Buttons List'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Property Editor'
Keymap: '3D View Tool: Select Box' not found for tool 'builtin.select_box'
