Keymap area in Preferences empty #68014
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#68014
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Acer Aspire 3
Windows 10
AMD Radeon Vega Mobile GRaphics
Blender Version 2.8 Candidate 3
Description: The problem I am having is that my keyboard and mouse do not register while in Blender program. They work in every aspect except Blender. I can use the drop down menus in Blender and type in the text boxes but thats it. I tried factory reset, using installer to repair, uninstalling and reinstalling. I also notice while going into preferences, if I go into Keymap, its blank. Their is nothing there.
Added subscriber: @Ahulse
Added subscriber: @ideasman42
This is how it looks when I click the tab. I have the most recent version of Blender. 2.8 worked for awhile and I made a few animations and renders. I had the original Beta 2.8 Blender when it started. The errors that have shown up are as follows; if I try to add an add-on it gives me the error code Traceback and something about Import Enum and others. I tried deleting the userpref file and it works afterward. However, this also gets rid of all my menu bars and what not so this is not an acceptable solution.
Added subscriber: @mont29
We'd need the errors messages from the console too, but that is most likely some kind of corruption of your installation. Please try a clean full-reinstallation, and try launching blender with
--factory-startup
option too…I have done a fresh install and have also done the factory startup but it did not fix anything. It still has an empty Keymap Preferences. at this point I have no idea what to do. Thinking back it seems that it happened when I updated my Laptop, I don't know if this would cause an error in the Python Registration. I have been trying all sorts of Blender Forums and they seem to think its that. This is the error message I receive in the Addon Preferences.
We are missing the whole error message here (please run from a command line, then you'll get everything, and can copy/paste actual text here instead of a screen cap).
Looks like you have a problem with an addon though, one way or the other (trying to register it twice because it's in two different places in your system, or something like that).
This is just a small portion because it was far too long to post.
Switching to fully guarded memory allocator.
Blender 2.80 (sub 75)
Build: 2019-07-29 09:41 AM Windows
argv- [x] = blender
argv- [x] = --debug
argv- [x] = --debug-gpu
argv- [x] = --python-expr
argv- [x] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\ahuls\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
Read prefs: C:\Users\ahuls\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
read file C:\Users\ahuls\AppData\Roaming\Blender Foundation\Blender\2.80\config\startup.blend
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
Using OpenGL 4.3 debug facilities
GL application marker: Successfully hooked OpenGL debug callback.
found bundled python: C:\Program Files (x86)\Blender Foundation\Blender\2.80\python
AL lib: (EE) ALCmmdevPlayback_mixerProc: WaitForSingleObjectEx error: 0x102
ValueError: register_class(...): already registered as a subclass
During handling of the above exception, another exception occurred:
ImportError: cannot import name 'MappingProxyType' from 'types' (C:\Users\ahuls\AppData\Roaming\Blender Foundation\Blender\2.80\scripts\addons\types.py)
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Edit Mode'
This issue was referenced by blender/blender@bb2394a298
The add-on
has a naming collision with Python's types module,I've adjusted add-on path order so this wont cause an error. although you should remove/rename
.Unfortunately the problem is still persisting, I am in the location you have given me for the types.py and it is not in that location. I had uninstalled and reinstalled one last time after you posted this, I don't know if that undid what you fixed.
Below is the error Log Code if needed.
when following the route from C:\ their is no such folder as AppData. So I have no idea what to do and when I went through Blender Foundation folder in the Program files folder. In the Addons folder their is no such file named types.py
I could only find this. file:/C:/Program%20Files/Blender%20Foundation/Blender/2.80/python/lib/sqlite3/test/types.py but it is in a completely different spot.
Not sure then, I can add
types.py
It's very confusing that you get an error importing a file you say doesn't exist.Since blender/blender@e8ffe25eb1, Blender now prints the name of the class being registered twice.
Could you try a build in the next day or two and see which class gives the error?
The first error:
Will now include a name after it which could help us find out whats going on.
By build do you mean re-downloading Blender completely. I am not a very techy person when it comes to coding so alot of this does not completely make sense to me but I am trying to follow along because I really love Blender and just want it working again.
Added subscriber: @EitanSomething
re download completely
The build will now be up to date, could you download it and try again?
I have downloaded it and am still experiencing the same issue. The Keymap preference area is empty and I cannot click on anything except menu tabs and no hotkeys work. blender_debug_output.txt
This is the full log, I hope this helps in someway, I will continue to look for stuff. I noticed that if I deleted certain files, like the preferences file it got rid of all the menu tabs but allowed me to click objects and use hotkeys. I'm sorry that you are having such a difficult time with my problem.
I also just noticed when I hover over brush options , the words Internal Error appear in bright red.
Changed status from 'Resolved' to: 'Open'
This isn't the output from a daily build, because the version is 2.80 not 2.81.
Try a recent build from https://builder.blender.org/download/
Added subscriber: @EAW
@Ahulse AppData is a hidden folder. To see it, you will have to follow the following steps :
https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
Hello, I am so sorry for such a late response. Thank you Campbell Barton I had no idea their was an experimental section. I have downloaded the build 2.81 and it is working perfectly. I do not have any current issues with it.
Thank you Evan Wilson I had no idea they were hidden files and was able to get my computer to reveal all hidden files.
Thanks for the heads up, I guess we can close that one as solved then.
