Being able to set the same location of proxies to source is not allowed in the filesystem
Open, Confirmed, HighPublic
Title:
Operating system: Windows 7
GPU: Radeon Vega 64, Divider version: 19.4.1
CPU: Intel Core i7-5960X
Broken: All of them
Worked: None
The settings in the proxy panel allow for the Proxies to be saved in the same location as the source.
It is not possible to create a folder that has the same name as a file (including extension), so Blender crashes.
From T67535#741176:
Callback:
N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64>N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\blender.exe --debug
Switching to fully guarded memory allocator.
Blender 2.81 (sub 0)
Build: 30/07/2019 17:01 Windows Release
argv[0] = N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\blender.exe
argv[1] = --debug
Note: No (valid) 'C:\Users\admin\AppData\Roaming\Blender Foundation\Blender\2.81\config\startup.blend' found, fall back to built-in default.
read file
  Version 280 sub 39 date unknown hash unknown
AL lib: (EE) UpdateDeviceParams: Failed to set 48000hz, got 96000hz instead
found bundled python: N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\2.81\python
drop file F:\Blender\BugFinds\T67535 VSE crash and failure to update\Cat.blend
Read blend: F:\Blender\BugFinds\T67535 VSE crash and failure to update\Cat.blend
read file F:\Blender\BugFinds\T67535 VSE crash and failure to update\Cat.blend
  Version 280 sub 75 date 2019-07-29 14:47 hash f6cb5f54494e
Starting work on proxy: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\proxy_25_part.avi
Couldn't open outputfile! Proxy not built!
Starting work on proxy: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\proxy_50_part.avi
Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run.blen_tc
Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run.blen_tc_part! Index build broken!
Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\free_run.blen_tc
Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\free_run.blen_tc_part! Index build broken!
Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\interp_free_run.blen_tc
Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\interp_free_run.blen_tc_part! Index build broken!
Starting work on index: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run_no_gaps.blen_tc
Couldn't open index target: F:\Blender\BugFinds\T67535 VSE crash and failure to update\VID_201907_trimmed.mkv\record_run_no_gaps.blen_tc_part! Index build broken!
Error   : EXCEPTION_ACCESS_VIOLATION
Address : 0x000000013F6B067F
Module  : N:\Temp\Blender\blender-2.81.0-git.af4dcc6073fa-windows64\blender.exe
Exact steps for others to reproduce the error from scratch
  • Factory Start-up
  • Add video
  • In proxy settings select Project
  • In the directory set to the same location as the source video
  • Build Proxies
  • Crash
Also see: T67535#741176
@Richard Antalik (ISS) If you have a better title, please feel free to change it...
Wouldn't a simple way to fix this be to not include the extension full stop?
Only downside would be the consistency in naming.
Maybe as a dirty fix; could be to check to see if the proxy is set to the source dir and if it is: skip having the full stop...
Richard Antalik (ISS) triaged this task as Normal priority.Jul 31 2019, 11:28 PM
Thanks for report.
As for fix I will have to think about that.
It's a bit struggle working with paths in C. I will come up with something, just could not resist to sigh loudly :)
Richard Antalik (ISS) raised the priority of this task from Normal to Confirmed, High.Jul 31 2019, 11:30 PM
Changing priority to high mainly because it will also crash Blender
Hi @Richard Antalik (ISS),
If you need a hand with any C, just let me know - I'm too busy with work to take on big tasks, but I can def find time to assist you with any C issues you're having.
@Richard Antalik (ISS) : I have added this to 2.81 milestone (since it was set to "High"), mind checking again?
That is correct.
I am focused on new features untill Sep 13 so I haven't really touched bugtracker.
