Online Manual / Online Python reference fails for anything related to CyclesRenderSettings
Confirmed, NormalPublicKNOWN ISSUE
Operating system: fedora 30, 5.1.16-300.fc30.x86_64
Graphics card: nvidia 970m, 430.26 drivers
Broken: rB46c22f33b252, master, 2019-08-01
Worked: 2.79.0
Choosing Online Manual / Online Python reference via context menue on any propertyrelated to CyclesRenderSettings throws an error
bpy.types.CyclesRenderSettings doesnt seem to be accessible via
In the default scene, Properties Editor, Render tab:
  • switch to cycles
  • on any property (e.g. sampling panel > render samples), choose context menu (RMB) > Online Manual / Online Python reference
  • error
  File "/build_linux/bin/2.81/scripts/startup/bl_operators/wm.py", line 1032, in execute
    url = _wm_doc_get_id(self.doc_id, do_url=True, url_prefix=self._prefix)
  File "/build_linux/bin/2.81/scripts/startup/bl_operators/wm.py", line 937, in _wm_doc_get_id
    rna_class = getattr(bpy.types, class_name)
AttributeError: 'RNA_Types' object has no attribute 'CyclesRenderSettings'
Seems like CyclesRenderSettings are not accessible via bpy.types even though it is documented as such https://docs.blender.org/api/2.80/bpy.types.CyclesRenderSettings.html
but instead only via context.scene.cycles or from cycles package cycles.properties.CyclesRenderSettings
Aaron Carlisle (Blendify) triaged this task as High priority.Jan 10 2020, 1:31 AM
Bastien Montagne (mont29) lowered the priority of this task from High to Normal.Jan 14 2020, 12:14 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".
There is no reasons to put that to high priority, this is a current limitation of the system, Cycles data is generated through python API, i.e. those are not 'real' RNA structures. Addressing this issue will require design and development work.
