bpy.data.node_groups is not accessible via the Python console #68053
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#68053
Operating system: Debian 10
Graphics card: Intel HD 4000
Broken: v 2.81 Alpha, Date 2019-07-30 20:50, Hash: 5359b7a03307 (latest daily linux 64-bit)
The following expression in the python console produces a key not found error:
In the scripting workspace, the executed python expressions window displays the same map access working if you go in the shader editor and perform some sort of action that operates on the
node_groups
map, such as changing the default shader specular value. The case sensitivity does not seem to matter - sometimes the printout window shows the string as "Shader Nodetree", sometimes as "Shader NodeTree".Exact steps for others to reproduce the error
bpy.data.node_groups["Shader NodeTree"]
in the consoleAdded subscriber: @gekko
Added subscriber: @lichtwerk
Confirmed, checking...
Will put on my desk for investigation
Added subscriber: @mont29
That is not technically a bug, although it is confusing (and a pain to handle in C code as well), 'root' node trees are not regular data-blocks, and are not available from
bpy.data
. They are closer to some private data of their owner (material, light, scene data-blocks), and should only be accessed through them. Thanks for the report anyway.@mont29: should we tweak the data-path-reporting to their respective owner then? (or is this this even imposiible? -- havent checked code yet...)
(inclined to repoen as TODO with low prio for my desk -- this has been bugging me as well, just feels like a bug -- same goes for #68054...)
