Obj sequence exporting does not keep vertex index order in each file
Closed, InvalidPublic
Operating system: Windows 10
Graphics card: GTX980
Broken: 2.80
(example: 2.79b release)
i tried to export a mesh with simple deformation animation to obj sequence files for using with Vertex animation tool in unity, but the import result is wrong, after importing back to blender i found out the vertex order of the exported ones are different from the original one.
  1. select the mesh with simple deformation animation.
  2. launch File -> Export -> Wavefront(obj)
  3. checked options: selected only, animation, apply modifiers, write materials, objects as obj objects, keep vertex order, other options are unchecked and keep path mode/forward/up as their default value
  4. export obj sequences
  5. import one of the obj back and check vertex index.
Bastien Montagne (mont29) closed this task as Invalid.
Keeping vertex orders are options in both exporting and importing side of the OBJ add-ons, if you enable it in both steps, then you'll keep your original order.
Enable 'keep vertex order' upon OBJ export is unable to keep original order. Could you double check.
you need to enable "keeping vertex order" for import as well.
