ScreenKeyCast does not detect repetitions with the i key in edit mode
Closed, InvalidPublic
platform: Windows
Broken:
version: 2.79 (sub 7), branch: blender 2.7 (modified), commit date: 2019-07-27 05:03, hash: e045fe53f1b0, type:
type:
build date: Sat 07/27/2019, 12:36 AM
in edit mode it does not detect the I key or repeated pulsations, and sweat with some more keys
example:
in edit mode
select 2 or more faces
press I ( insect faces )
press again I ( to inset individual faces )
Try this with all the keys and found that some have this problem
William Reynish (billreynish) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Aug 1 2019, 7:38 PM
I think you've used translation? I don't follow this report, unfortunately.
hi, I think it's about the built in "I" key insets.
To reproduce: Select a face, "I" to inset is a modal op. click to stop the modal.
Make sure the cursor is in the center of the inset face. Press "I" again and there appears to be no modal op. The menu still works and the second inset can be set from there.
This largely depends on cursor position, if the cursor is too close to the center of the inset face it appears not to work. If the cursor is at a reasonable distance from the face to inset, all works as expected.
Bastien Montagne (mont29) raised the priority of this task from Needs Information from User to Waiting for Developer to Reproduce.Aug 20 2019, 12:13 PM
Michell (Michell) renamed this task from does not detect repetitions with the i key in edit mode to ScreenKeyCast does not detect repetitions with the i key in edit mode.Sep 16 2019, 4:41 PM
Michell (Michell) updated the task description. (Show Details)
Michell (Michell) added a comment.EditedSep 16 2019, 4:46 PM
ammm let me see ...
For some reason I think I forgot to put that this is about screencast key addon, the truth is that remembering this I actually did it without any interest for some quite awkward attitudes that have here and to prevent me from being marginalized in their beautiful autocrasia of the candy world I kept quiet, but well I corrected it because I have a mania that does not leave me alone and causes me many problems, and is not leaving things halfway or badly done, I regret having bothered you, but I no longer Excites both blender and a year ago, even if they fix it it will be good for others, change 3D platform
hi the screencast addon is maintained outside of Blender, there's a couple of versions around iirc. I'm not sure what the issue here is. We originally removed this addon from Blender some time ago due to issues with holding down keys or rapid key presses. Your also trying to do a key press during a modal op. I tried that too and it did not work properly either. You could try to contact the author of the addon and report an issue.
Closing as invalid
