Adding a corrupt video crashes/confuses Blender #68091
6 Participants
Reference: blender/blender#68091
Operating system: Windows 7
GPU: Radeon Vega 64, Divider version: 19.4.1
CPU: Intel Core i7-5960X
Broken:
blender-2.81.0-git.d8fb63661b32-windows64
Broken: 2.80
Worked: 2.79b
Loading a corrupted video in 2.80 will crash Blender, in 2.79b the video simply won't load.
This can happen in two ways:
When first opening the VSE, having the frame rate try to match the first video that's imported.
If the frame rate is already set, once the playhead reaches the corrupt part of the video.
Exact file for others to reproduce the error from scratch
I can't find a corrupt video other than this one (and I didn't have the heart to upload 4 gigs to phab)
The video stream in intact upto about 2:20. Download Here
See description for reproduction steps.
Added subscriber: @ChristopherAnderssarian
Added subscriber: @dfelinto
Can't you reproduce this messing with a smaller file in a text editor?
Thing is: other corrupt videos give errors like in 2.7X, but I'll give it a go...
Added subscriber: @Sergey
I will have to ask @Sergey if he will be able to look into this.
Unfortunately I don't have enouh RAM(4gig) to debug this.
I will hopefully have new workstation, but that would be near 2.82 cycle
Added subscriber: @dr.sybren
I don't think you need a huge amount of ram to debug this, just set a breakpoint in
startffmpeg
and step through untilanim->duration
is assigned.The video file is claiming to have
5,175,604,057,416
frames, which is obviously wrong.The average framerate is set to weird value of
2603 / 902820173
.The deprecated framerate field is set to
30 / 1
.Blender's logic is so that:
avg_frame_rate
unless either of those are true:avg_frame_rate
is set to 0.In other cases
r_frame_rate
is used.In order to solve the issue we need to make it so duration in frames is deducted to some sane value in
startffmpeg
.If we somehow use
r_frame_rate
in this case then the duration will be calculated to 0, making Blender to show corrupted/unsupported warning (which is kind of expected).But it is unclear to me what should the policy be between using
nb_frames
,r_frame_rate
andavg_frame_rate
. Someone need to dig into the history and see why those were added and possibly tweak code around.P.S. There is no-so-much-comprehensive tests which one can run with
ctest -R ffmpeg
.P.P.S. CCing Sybren, he was solving some of the duration detection issues not so far in the past.
P.P.P.S. We should be able to cut the video after few kilobytes and add it to the regression suit once we're done with this if that's ok with @Christopher_Anderssarian.
ffprobe -v error -hide_banner -print_format json -show_streams -show_format
shows the following framerate/time related fields for the video stream in that file:So Blender "correctly" reads the fields from the video file at least. The question now is how to recognise that the data is useless, or to turn the at-the-moment-useless data into correct data.
ffplay thefile.mp4
does play back the file correctly, so there must be a way to handle this.Added subscriber: @iss
I can confirm problems with this video file, but I cannot confirm the crash of Blender. I have some ideas to handle the corruption, though.
Here is a smaller example file that's corrupted in a similar manner: the number of frames is way too high: F7758185. The patch in D5853 has a heuristic that corrects this error.
Adding a corrupt video crashes Blenderto Adding a corrupt video crashes/confuses BlenderThis issue was referenced by
71f2229b0d
Are you saying you can play the entire video?
For me playing the video in Blender and VLC work upto ~2:20 then both crash...
On my system both Blender and ffplay play the video until ~2:20 and then stop playback. Neither of them crash.
