Settings for Select root and Select tip in particle edit mode are missing
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: rB507ffee6e1f4
The select root and select tip command no longer bring up the setting panel to deselect or toggle select
Create a hair system for the default cube, go to the particle edit mode and select root/tip -> no settings available
Philipp Oeser (lichtwerk) triaged this task as Waiting for Developer to Reproduce priority.
This was changed in rB423d9086e64e / D4665 [and rB98e0bd90f45f]
Not sure if this has a deeper reason to hide these? (just flipping the switch on WM_operator_properties_select_action to not hide it in the UI reveals it is not working reliably though...)
I think this is useful, no? Could check if I can make it work again [and the reactivate in the UI], but before that, I'll ask for other opinions
CC @Sebastian Parborg (zeddb)
CC @Brecht Van Lommel (brecht)
CC @Campbell Barton (campbellbarton)
Brecht Van Lommel (brecht) lowered the priority of this task from Waiting for Developer to Reproduce to Confirmed, Medium.
Yes, I think we should make these options visible for select root and tip.
