Instant crash at startup (fatal python error) #68143
Reference: blender/blender#68143
Operating system: Windows 10
Graphics card: Nvidia GeForce RTX 2070
Broken: 2.80
Worked: 2.79
Newly installed Blender 2.80 crashes instantly at startup. There were no such issues with a previously installed Blender 2.79 version.
Running it from the command line shows that there is a python error (see attached logfile). log.txt
Added subscriber: @Robert-Lasch
Added subscriber: @LazyDodo
does it work when you start blender using the
blender_debug_log.cmd
batch file located in your blender folder?It does not work and produces a log file with the same error.
blender_debug_output.txt
was this the .msi installer or the .zip?
It was the .msi installer.
It might also be relevant that I have other python distributions installed on the system besides the one bundled with Blender. Could those be interfering with the bundled version?
It could be, but the batch file i made you run temporary reset the PYTHONPATH environment variable that it generally uses to find 'the wrong python' so yeah i'm kinda stumped here,
My running theory was the unzip bailed out prematurely but given you didn't use the .zip that's out the window as well.
Added subscriber: @rjg
Looks like an encoding/decoding problem.
0xfc
is indeed not valid in UTF-8. Do you happen to have anü
somewhere in a path or file that may be read by Blender? I suspect there is some error where wide characters aren't properly converted to multibyte.I just checked using Process Monitor (https://docs.microsoft.com/en-us/sysinternals/downloads/procmon).
It does not look like Blender is opening any files besides ones from the python/lib directory in the blender installation path. Those shouldn't have any encoding issues, as they were just freshly installed.
The installation path itself also does not contain any umlauts.
Is there anything else I could do to figure out which file is causing the issue?
Just figured it out. There was a .pth file in a site-packages folder of one of the other python distributions on the system. That file pointed to a path containing an
ü
.Apparently this was never a problem for the already installed python distribution, but the one bundled with Blender was sensitive to it.
Removing the offending path in the .pth file resolved the problem.
Thank you everyone.
Added subscriber: @ideasman42
@Robert-Lasch Thank you for investigating this!
@LazyDodo @ideasman42 Is there something about the encoding of .pth files that Blender currently doesn't consider, but can and should? I guess the problem is that the file encoding is assumed to be UTF-8 without trying to identify the actual file encoding?
Ideally python would not be looking at anything outside it's own folder, and should leave other pythons on the system alone, If someone can talk me into re-creating the conditions that @Robert-Lasch was having did i'd be happy to take a stab at this
We try not to interfere with Python defaults so Python developers get an environment which works like a regular installation, however we need to set the standard encoding since Blenders data-block names are
utf-8
.Checking site-packages
site.py
where the error is raised & Python is usingopen()
without any encoding arguments when loading the.pth
files.This might be a bug in Python, since it could set the encoding:
At the very least it could warn but not prevent Python from starting entirely.
Note, this error can be redone in Linux easily.
Now Python & Blender fail to start.
