keep sharp option on weighted normals modifier not working #68170
2 Participants
Reference: blender/blender#68170
Operating system: Win10
Graphics card: 960m
Broken: (example: 2.80 release)
When using the "keep sharp" option on the weighted edge modifier, only the edges that have been marked with sharp edges should be sharp. Currently, when doing this all edges become sharp, regardless of what edges are marked sharp.
The only way I have found to mix sharp edges in conjunction with the weighted edge modifier is to use an edge split modifier before the weighted normals modifier. This shouldn't be needed as the weighted normals modifier should be able to do this itself by modifying the normals instead.
Have attached a basic example. The recessed edges on the top of the cube are marked sharp, but as can be seen, all edges become sharp when using the keep sharp option in the modifier.
weighted_egde_normal_bug.blend
Added subscriber: @JamesRedmond
Added subscriber: @akaChris
This is actually not a bug (I thought so myself at first). You have to set your object to: shade smooth. then you need to up the auto smooth angle value (needs to be above 45degrees to pick up normal bevels. to be save go above 50). Works with your test file. Hope that helped!
