Problems with materials when changing Color (Meshes and GPencil materials)
Open, Needs Triage by DeveloperPublic
Graphics card: Intel(R) HD Graphics 4000 Intel 4.0.0 - Build 10.18.10.4252
[Blender deja de responder al cambia color de material y herramientas en Grease pencil. y se detiene momentáneamente al cambiar el material y colores en Mesh]
[entrar en modo Draw de Grease pencil, seleccionar otra herramienta. o hacer clic en material.
seleccionar un Mesh, hacer clic en material, cambiar color]
perdón que no escriba en ingles. Por lo demás del software esta fantástico, gracias por el trabajo que hacen.
(Translate)
Blender doesn't respond when change material color and GPencil tools, also some lag when changing materials and colors in Mesh.
To reproduce:
  1. Enter in Draw mode, select other tool or click material.
  2. Select a Mesh and click in material to change color.
Antonio Vazquez (antoniov) updated the task description. (Show Details)
Antonio Vazquez (antoniov) renamed this task from problemas con grease pencil y materiales to GPencil: Problems with materials.
@Germano Cavalcante (mano-wii) I cannot repoduce in Windows with NVIDIA card. could be related to Intel GPU?
It looks some lag in de driver when compute the preview or something like that.
@Manuel Cifuentes (MemeCifuentes)
As a first step, I suggest you update the video driver to the latest available version.
(Como primer paso, te sugiero que actualices el driver de video a la última versión disponible)
Antonio Vazquez (antoniov) renamed this task from GPencil: Problems with materials to Problems with materials when changing Color (Meshes and GPencil materials).Sun, Aug 4, 10:38 AM
I don't know if I follow the steps correctly, but I can't reproduce any of the bugs mentioned.
Intel(R) HD Graphics 4000 version: 4.0.0 - Build 10.18.10.5069
