Cryptomatte affected by Color Space change in OpenEXR multilayer.
Open, Confirmed, MediumPublic
Graphics card: Intel(R) HD Graphics 4000 Intel 4.0.0 - Build 10.18.10.5069
(also tried on the latest 2.81 Beta)
I don't think it's a bug, but rather something that hasn't been thought of. Currently when you use Cryptomatte and export an OpenEXR Multilayer file, if you then import it into the compositor and change its color space to something other than linear, the cryptomatte passes will also be affected by the color space change and will no longer work properly.
Cryptomatte color picking with linear color space :
Cryptomatte color picking with linearACES color space :
Here is an example .blend with an EXR Multilayer file packed into it :
Download the example file.
First set the image in linear color space.
With the cryptomatte node, pick the color of the chair for example as in this image :
Then show the generated mask of the cryptomatte node :
In linear color space, everything works as expected, the cryptomatte node masks only the chairs.
Then, set the image color space in linearACES for example.
(you'll notice that the color picking output of the cryptomatte node isn't displayed the same way as in linear color space)
Delete the values in the cryptomatte node.
Pick the color of the chairs like the first time.
The mask does not only include the chairs as expected but also other objects, and the edges of the mask are too sharp compared to the same mask in linear color space.
sineo (sineo) updated the task description. (Show Details)Aug 4 2019, 9:39 PM
Sybren A. Stüvel (sybren) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Aug 6 2019, 4:33 PM
Please attach a minimal blend file with the required EXR file(s).
sineo (sineo) updated the task description. (Show Details)Aug 6 2019, 8:48 PM
I can confirm that the look of the cryptomatte in the compositor background changes when you change the Color Space setting of the EXR image node, including seeing edges:
However, I can't confirm a change in behaviour when picking objects via the Cryptomatte node.
Please describe the steps to reproduce in a way that we can literally follow, and clearly describe your expectations. Example "when clicking on this object (include a screenshot with an arrow where to click) the selected value should be X but when I set the Color Space to LinearACES it is Y". That makes things easier to confirm than "it behaves very weirdly".
sineo (sineo) updated the task description. (Show Details)Aug 9 2019, 8:00 PM
Bastien Montagne (mont29) raised the priority of this task from Needs Information from User to Waiting for Developer to Reproduce.Aug 20 2019, 11:29 AM
Jacques Lucke (JacquesLucke) lowered the priority of this task from Waiting for Developer to Reproduce to Confirmed, Medium.Aug 21 2019, 1:51 PM
I can confirm the issue. I guess the solution is to have a color space per pass?
If I understand it correctly, the cryptomatte passes should never be modified by some color space transformation. Is that correct?
Need your help here, @Brecht Van Lommel (brecht), @Stefan Werner (swerner).
Correct. Cryptomatte is non-color data (even though it is stored as RGBA) and should never undergo any kind of transformation.
I'm not sure if and how this is handled by other software using Cryptomatte. Presumably there would be some metadata on the OpenEXR pass, or the names of channels are different than RGBA indicating that it is non-color data? We should try to match whatever the standard is if possible.
Cycles should then also indicate cryptomatte passes as non-color data when defining them in intern/cycles/blender/addon/engine.py.
