Constrained Delaunay Triangulation #68277
2 Participants
Reference: blender/blender#68277
Problem Description
This design task is about making a 2D Constrained Delaunay Triangulation (CDT) library function for Blenlib. A Constrained Delaunay Triangulation is a triangulation with "nice edges" that includes "constraints", which are vertices, edges, and faces that must appear in the output. For edges and faces, the output may have to subdivide them in order to make a triangulation. A byproduct of doing the CDT is that the algorithm will discover all the intersections, coincident vertices, and overlapping edges, as a by-product of doing that triangulation.
This task has several motivations.
Some requirements arise from these motivations:
Algorithm
A promising paper for doing CDT, paying close attention to overlaps etc., and keeping track of how the output relates to the input, is "Fully Dynamic Constrained Delaunay Triangulations”, by Kallmann, Bieri, and Thalmann.
This works by incrementally adding new constraints. A CDT is always maintained, and each new added vertex or edge modifies the CDT. It first needs to find the location of where to insert the vertices. It does that by searching through triangles (using "Do these three points form a clockwise angle?" tests) to get to the triangle where the point belongs. It may actually coincide with an existing vertex, or it may be on an existing edge. After points are inserted to make a triangulation, edges are flipped until the CDT condition still holds. Edge constraints are more complicated: after the endpoints are found and inserted if necessary, a search from the beginning vertex to the end vertex discovers which edges and vertices are crossed. If a constraint edge is crossed, it needs to get the intersection point inserted. Other crossed edges (non-constraint ones) can be removed, and then afterwards all the non-triangle faces are retriangulated, ensuring CDT condition during retriangulation. Face constraints are just a closed cycle of edge constraints, so the same algorithms apply.
To keep track of which input elements go with which output elements, a list of "input ids" is kept with each vertex, edge, and face in the CDT. Those ids are updated appropriately as edges and faces are split, and as vertices are merged into other vertices.
The running time of the algorithm from the paper is O(n^(4/3)) if point location uses a method where you sample O(n^(1/3)) places in the CDT and find the one closest to the point-to-be-inserted, and then start to search from there. One could also use a kd-tree and make a faster O(n log n) running time.
I propose use doubles for all the arithmetic in the routine, to help minimize the precision problems that happen whenever one does intersections of nearly parallel lines.
API
The input can be described by separate arrays of vertices, edges, and faces. The vertices need to have 2d coordinates. The edges and faces can be described with indices into the vertex list. The faces are really arrays of variable length arrays, which are hard to do in a C API. I propose putting all the coordinates for all faces in one array, and using separate arrays to store the starts and lengths of each individual face. This is similar to how Blender represents Mesh faces.
The output can be similar for vertices, edges, and faces. It is very hard to predict how much space will be used for these (at least without grossly overestimating in the usual case). So it is hard to follow common Blenlib practice of having the caller pass in the allocated space required. I propose passing back the output as allocated arrays, which the user must free. A convenience routine can be added to the API to free the whole output structure and its allocated arrays.
Along with vertices, edges, and faces, we need to let the caller know how the output elements relate to the input elements. I propose using the same flattened array with extra start and length arrays used for representing faces to represent the list of input ids that go with each output element. They will be returned in the output structure too.
Added subscribers: @howardt, @CareAgain, @nokipaike, @capnm, @scorpion81, @cwolf3d, @DuarteRamos, @ideasman42
Added subscriber: @item412
