Particle system baking not working in Python API #68303
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#68303
Operating system: Arch Linux
Graphics card: RTX 2080
Broken: (All, latest check: 2.80)
This code runs OK with no errors except that it does nothing. I have followed the similar patter as when baking smoke or fluid.
The cache is empty when I open the file afterwards or try to render. When I set
the cache folder is created but can't be used by the blend file.
Running as:
simpleParticles.blend
bake.py
Added subscriber: @ichlubna
Added subscriber: @dr.sybren
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/wiki/Process/Bug_Reports
Marking as "Incomplete" until the requested information/data is provided.
Sorry, fixed!
This makes sense, as your script doesn't save the blend file after baking. Adding
bpy.ops.wm.save_mainfile()
at the end of the script solves both on-disk and in-memory baking.Marking as 'Invalid' as this isn't a bug in Blender.
I see, thanks but why doesn't this happen when baking for example smoke in the same way?
EDIT: I guess it's because the rest creates external cache directory.
