Using "a" hotkey in nested collapsible menus only affects the parent menu #68317
Closed
opened 2019-08-06 16:21:02 +02:00 by Danny McGrath · 11 comments
Member
Blender 2.80 release
In this screenshot:
If you try to use the "a" key to expand and collapse the menus, it works fine, but not in sub menus. Seems like a bit of a design bug? Originally discussed here .
Blender 2.80 release In this screenshot: ![ac569b9b81ee5b900b06c0aa3e84064dc85525a1.png](https://archive.blender.org/developer/F7651700/ac569b9b81ee5b900b06c0aa3e84064dc85525a1.png) If you try to use the "a" key to expand and collapse the menus, it works fine, but not in sub menus. Seems like a bit of a design bug? Originally discussed [here ](https://devtalk.blender.org/t/uing-a-hotkey-in-nested-collapsible-menus/8795).
Author
Member
Added subscriber: @dmcgrath
Added subscribers: @brecht, @WilliamReynish
Brecht Van Lommel was assigned by William Reynish 2019-08-06 18:26:05 +02:00
@brecht a small bug in sub-panels it seems. Feel free to re-assign as you wish.
Brecht Van Lommel removed their assignment 2019-08-07 04:22:00 +02:00
We don't usually assign low priority bugs to anyone.
Added subscriber: @pedroreis.ad
I have a question regarding this, about what would be the best behaviour for the end user, assuming that all sub-panels would correctly open when 'a' is pressed.
If I click 'a' on a sub-panel that is already opened, should it only close that sub-panel, or should it close the entire panel?
In my opinion as an user, if I clicked 'a' then I wanted everything to open up, or everything to close down, regardless of whether I clicked on a sub-panel or not. Currently, if I have an open panel, but a closed sub-panel, and I click 'a' on that sub-panel, its state would be toggled, but it would close the entire panel. This means the sub-panel is now open, but on a closed panel, which doesn't seem useful.
What are your opinions on this? I think I can do this task, but I don't know what should be the best solution for the user.
I have a question regarding this, about what would be the best behaviour for the end user, assuming that all sub-panels would correctly open when 'a' is pressed. If I click 'a' on a sub-panel that is already opened, should it only close that sub-panel, or should it close the entire panel? In my opinion as an user, if I clicked 'a' then I wanted everything to open up, or everything to close down, regardless of whether I clicked on a sub-panel or not. Currently, if I have an open panel, but a closed sub-panel, and I click 'a' on that sub-panel, its state would be toggled, but it would close the entire panel. This means the sub-panel is now open, but on a closed panel, which doesn't seem useful. What are your opinions on this? I think I can do this task, but I don't know what should be the best solution for the user.
I've been trying to fix this for a couple of weeks on and off, and it seems like I hit a wall, and I'm having a bit of troubles uncovering how I can go about this.
I intended to minimize at the maximum the amount of code that was being called, and so I had the idea of only calling the ui_handle_panel_header function for the main menu, not the sub-menus, and cascade the collapse or opening to all the children.
However, I need the uiBlock responsible for that panel for that to happen. Unfortunately, even after "ui_handle_panel_header" the inside blocks haven't been "spawned" inside the area, so there's no way to access them.
I thought about simply invoking "panel_activate_state()", with the correct child panel, didn't work. Tried to go through all the ScreenArea in the Screen, go through all the uiBlocks, but it almost looks like they're non existent.
@brecht Can you give me a pointer at where to look at, or maybe indicate me someone who might?
I've been trying to fix this for a couple of weeks on and off, and it seems like I hit a wall, and I'm having a bit of troubles uncovering how I can go about this. I intended to minimize at the maximum the amount of code that was being called, and so I had the idea of only calling the ui_handle_panel_header function for the main menu, not the sub-menus, and cascade the collapse or opening to all the children. However, I need the uiBlock responsible for that panel for that to happen. Unfortunately, even after "ui_handle_panel_header" the inside blocks haven't been "spawned" inside the area, so there's no way to access them. I thought about simply invoking "panel_activate_state()", with the correct child panel, didn't work. Tried to go through all the ScreenArea in the Screen, go through all the uiBlocks, but it almost looks like they're non existent. @brecht Can you give me a pointer at where to look at, or maybe indicate me someone who might?
Added subscriber: @mano-wii
This seems to be a task for #63726 (User Interface Module ) and not a bug.
This issue was referenced by a8766de5d5
This issue was referenced by a8766de5d59be699f47f7daedf8ac35f46e9b2e2
Member
Hans Goudey self-assigned this 2020-08-27 21:23:21 +02:00
7 Participants
Reference: blender/blender#68317
