When i click on layout i get error
Closed, DuplicatePublic
I have steam version of blender and 64 bit windows 8.1
I have error with wm.py file on lines 524 and 83
Demeter Dzadik (Mets) triaged this task as Needs Information from User priority.
Having the full error would save some developer time hunting down where those lines in the code are called from. And saving developer time is essential in <current year>. A screenshot would work, but if you can't do that, you can change one of the panels in blender to the "Info" type, and you should be able to copy and paste the error from there.
You could also try loading factory settings via File->Defaults->Load Factory Settings. This is not permanent, so your preferences shouldn't get lost, unless you save them. Although you should probably keep a backup just in case.
