Improve Interior Face Selection Method #2
Confirmed, LowPublicTO DO
Operating system: Win 10 Pro
Graphics card: nVidia GeForce GTX 1070ti
Broken: tested in 2.80 stable and 2.81-dcad1eb03ccc
In Edit Mode Select -> Select all by Trait -> Interior Faces does not select all expected Faces.
In the attached blend file try to select the interior faces by trait and nothing happens. The object was created by moving a default cyclinder and UV sphere into each other and merging the vertices at the spheres equator by distance. After the merge the top face of the cylinder is selected by trait as expected while the lower faces of the sphere are not.
Related Objects
Can confirm, doesn't even work with a cube within a cube.
This seems to be working as it is described in the tooltip.
Select faces where all edges have more than 2 face users.
I have attached a simple blend file with a cube inside a cube. I then created edges from the interior cube's to the exterior cube's vertices, but only filled in the faces on one side to make it easier to differentiate. Using Select All by Trait > Interior Faces results in the selection pictured above. I am posting the file here in case anyone would want to use it.
Having not used this feature before, the name "interior faces" made me first think that it would select the "faces that are enclosed within/inside of a fully enclosed/water tight mesh." I apologize as I am not sure of the proper term/terms for describing this geometry.
This seems like a case of unfortunate naming for this function. However, I do not have an alternative name to suggest.
Campbell Barton (campbellbarton) changed the task status from Duplicate to Unknown Status.Sep 8 2019, 7:07 PM
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Low.
Campbell Barton (campbellbarton) edited a custom field.
Campbell Barton (campbellbarton) renamed this task from Interior Face Select by Type not working to Improve Interior Face Selection Method #2.Sep 8 2019, 7:09 PM
