Blender (MacOS, v2.80-release and v2.81-git build) crashes with "Segmentation fault: 11" while rendering an animation
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580X OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Broken:
  • version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: rBf6cb5f54494e
  • version: 2.81 (sub 1), Commit date: 2019-08-06 20:27, Hash f4e27bc2c981
Worked: unknown
Blender crashes regularly with Segmentation fault: 11" while rendering an animation
This is not a neatly defined crash. While rendering a 2100-frame animation, Blender crashes regularly. With the release build, this seems to be every 100 to 200 frames or so. With a local compiled 2.81 version, the crash is more often, sometimes after 10 frames.
The .blend file is on a local SSD, the output (frame per image) is written to an SMB share on a NAS.
Crash files:
If needed, I can provide the .blend file.
Update: storing output in a local directory does not change the crash behavior.
Additional crash files:
I'm replicate this issue since I have the same hardware. Do you use EEVEE or Cycles? Will this happen if you render 250 frames of the default scene?
I am using Cycles.
I tried your suggestion with 2.80 RC2 build, the 2.80 official build and a local compiled 2.81.
Rendering a 500-frame animation of the default scene did not reproduce the crash.
A partial test with Eevee (approx 300 frames) also did not reproduce the crash.
Can you share something minimal that reproduces the crash?
I will try that as soon as I can and update here after 'elimination'.
Sybren A. Stüvel (sybren) triaged this task as Needs Information from User priority.Thu, Aug 8, 6:29 PM
It seems to have been a corruption in the .blend file.
I appended the components into an empty file and now Blender (2.81, local build) properly renders all 3000 frames in one go.
Can you please close the task?
