DXF_Exporter don't work with besier curves
Closed, InvalidPublic
Broken: All
Worked: None
DXF_Exporter exports only polygon edges, don't exports besier curves
This is test scene with def circle
It inclue working script from https://blender.stackexchange.com/questions/9305/export-bezier-curves
Looks like script exports true besier, but in three.js format i cannot to use it (i need universal dxf)
export js result
If i convert this quad to mesh, DXF_Exporter exported as poly lines
This is dxf made in Freecad, this is what i need for
It will be super if someone improve this musthave feature.
Thank you!
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Invalid.Aug 8 2019, 12:11 PM
The exporter included in blender has no official support for beziers.
Think what you could do is:
  • have a look at https://cad4arch.com/dxf_exporter/ (there is another version of the exporter that has support for this), this is from the same author that maintains the version officially supported in blender
  • you could export (nurbs) curves to OBJ instead [with the Write Nurbs option], not sure if this can be imported correctly in Freecad (or wherever you need it)?
  • (not recommended, speculative, if you're a coder: check the DXF exporter in blender, there is code for curves [but commented in many places] -- I havent tried this, this could possibly be made working by uncommenting... it is GPL after all...)
That all being said, this is not officially supported and looks more like a feature request [which is better suited at places like https://blender.community/c/rightclickselect/], afraid we have to close this...
