Improve Interior Face Selection Method
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.35
Select > Select By Trait > Interior Faces also selects outer faces
Open up
which contains a menger sponge at level 3; also contains a script to generate menger sponges
0.) go into edit mode
1.) select all
2.) merge by distance (aka remove doubles; merge dist: 0.0001m)
3.) deselect all
4.) Select > Select By Trait > Interior Faces
Result of Interior Face Selection: Does also select additional faces on the outside of the mesh (as shown below in picture01)
  • picture01 showing, that not only the interior faces are selected
  • picture02 showing, that interior face selection works for the menger sponge at level 1
Could also relate to the problem referred to in the blender source code comment:
C:\blender-git\blender\source\blender\editors\mesh\editmesh_select.c
/** \name Select Interior Faces
bool EDBM_select_interior_faces(BMEditMesh *em)
Campbell Barton (campbellbarton) renamed this task from Interior Face Selection also selects outer faces to Improver Interior Face Selection Method.Aug 8 2019, 9:42 AM
Campbell Barton (campbellbarton) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
Campbell Barton (campbellbarton) changed Type from Bug to To Do.
This is a known todo, listed it here T63731: Modeling Module
Campbell Barton (campbellbarton) renamed this task from Improver Interior Face Selection Method to Improve Interior Face Selection Method.Aug 8 2019, 9:45 AM
The description of the Interior Face Selection Method does what it should be doing:
"Select faces where all edges have more than 2 face users" not sure what users are. Someone said that it could be also refered to as "connected faces".
So yes; it would be rather an improvement than a bug fix.
A more minimal example of interior face selection: (a simple plus made out of 5 boxes merged)
