UV/Image editor: Remove Display Edges
In Blender 2.80 UI an option appeared with the name "Display Edges". it is indeed implemented in the RNA/DNA, but there is no logic connected to it.
In Blender 2.79 I am not able to see this option, might be an unfinished idea or legacy. whatever the reason we need to implement it or remove the code and manual.
the option was introduced by rBa3bb385ca0ba: Edit Mesh: Move Edit Mesh display settings to overlay's so seems like idea what was later removed
Jeroen Bakker (jbakker) updated the task description. (Show Details)
Jeroen Bakker (jbakker) triaged this task as Normal priority.
Jeroen Bakker (jbakker) renamed this task from UV/Image editor: Display Edges needs to be implemented or removed. to UV/Image editor: Display Edges needs to be removed..Aug 9 2019, 1:31 PM
Jeroen Bakker (jbakker) renamed this task from UV/Image editor: Display Edges needs to be removed. to UV/Image editor: Remove Display Edges.Aug 9 2019, 3:30 PM
Jeroen Bakker (jbakker) closed this task as Resolved.Tue, Aug 27, 4:21 PM
