decimate modifier "planar" broke window selection in os and other apps. also after reboot without opening blender.
Open, Needs Information from UserPublic
Graphics card: GeForce GTX 980M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.71
after blender crash, my mouse now has issues selecting stuff in another window.
like now, while i type, i can't click out of my browser, for example to close blender or select anything in the windows-start-menu.
i had to "alt-tab" and "arrow-key" my way through the report website XD
precise:
(i hope its not something really stupid...)
  • changing to another window in the os with alt-tab works.
  • as soon as i click in it, even to close it, it becomes unactive.
  • reactivating with alt-tab works. clicking not.
  • when i press "ctrl-alt-del" and start clicking in the gray screen and go back, selection and clicking in the active window works
  • but selecting something out of it not.
  • have to "alt-tab" to focus another window, "ctrl+alt+del" then click and come back, to be able to work in it.
edit:
i reinstalled blender and rebooted a few times. problem seems gone. i feel a bit stupid now.
decimate with "planar still might be a problem.
so i'll leave this open for now.
edit2:
nope. still happens.
dont know how and why. or when and when not.
any information about what might be going on here is appreciated.
thx in advance.
  • imported an obj from a meshroom photoscan (https://alicevision.org/#meshroom)
  • used decimate modifier
  • selecting "planar" killed blender
  • had to "ctrl+alt+del" but didn't help, os freeze.
  • had to hard-shut-down (just power-off)
  • tried to reopen the file. same problem.
  • removed the file (i thought: whatever, reimport, avoid "planar", no problem)
  • file gone. problem still here. help.
... sorry, cant use drag&drop to attach file.
but i still have the obj file. if needed i'll find a way to hand it over.
paul simon heyduck (paulsimonheyduck) renamed this task from after blender freeze window selection is broken in os and other apps. also after reboot without opening blender. to decimate modifier "planar" broke window selection in os and other apps. also after reboot without opening blender..Mon, Aug 12, 10:45 PM
can you upgrade to latest drivers (431.xx) from Nvidia support site, now you use a quite old drivers and check newly for you problem
to upload a file here you just click on cloud icon upper insert text box, second icon from right on left icon block
[edit] meshroom generally produce a very dense mesh, IMO is better pre simplify these mesh inside meshroom (IMO work very well), before import it in Blender and try to decimate
Brecht Van Lommel (brecht) raised the priority of this task from Normal to Needs Triage by Developer.Tue, Aug 13, 5:37 AM
Campbell Barton (campbellbarton) triaged this task as Needs Information from User priority.
Please include a blend file which crashes when the modifier is added.
